Urive Albatross IV
Full HD- Full HD High-quality video recording
It provides clean & vivid video quality (front/rear: 1920x1080) and optimal viewing angles (front: 124°, rear: 109°) by recording all of the important scenes while driving and parking monitoring mode. It provides max. 30fps clear videos for front with the Urive’s tuning technology
4” wide touch screen
The front and rear real time video and recorded videos can be viewed on a 4” wide LCD screen. In addition, thanks to a smart GUI-based touch method, environment setting and SD card formatting can be carried out directly from the LCD.
Premium IPS Panel adapted High-quality & low-capacity video recording
It demonstrates clearly the high-resolution images from any viewing angle at IPS panel. This product is capable of recording high quality images in low doses to adopt high profile codec.
LDWS(Lane departure warning system)
LDWS operates in a way that the front camera recognizes the road lane in real time and, if the driver falls asleep while driving or drives poorly, causing the car to depart the lane, it will notify about it through the preset warning sound.
FCWS(Forward collusion warning system)
FCWS operates in a way that the front camera recognizes a vehicle in front while driving and analyzes the movement of vehicles on the same lane. If it detects the possible collision in advance, gives a warning sound.
FVSA(Front Vehicle start alarm)
FVSA provides warning information when the front car start to go.
Format Free
One of the recorded image on the SD card is not stored across into many pieces, due to sudden power loss, if the images are not perfectly finished recording, and the file can be played. The product consists of a stable system, users do not need to format the SD card regularly.
Excellent for heat resistance (Auto-saver)
It has Auto-saver function to protect by itself from the heat. It will turns the LCD off when the temperature is higher than its set temperature. Even if the LCD is off, it records all the videos.
Smart parking event notification
Urive Albatross4 gives parking event information with a red LED blinks even when the driver is outside of the car. It also gives voice guides about "parking event occurred" when it switch from parking mode to driving mode.
Wide Dynamic Range
Urive Albatross4 can record optimized videos with WDR (Wide Dynamic Range) function. Even though there are less lights like tunnels, it can amend its dark parts to recognize any car number plate, and milestones easily.
