mentadent
- Nov 14, 2020
- London, UK
- United Kingdom
- VIOFO A139
Has anyone else found that USB-PD will not power this cam?
not this camera as I don't have one but I have found the same with other cameras using a PD power supplyHas anyone else found that USB-PD will not power this cam?
Only 2 watts per channel!Thanks.
I tested power usage and it uses about 6 watts if anyone is interested. Seems a lot.
Yes, I have noticed that, but I'm not sure how hot the card actually gets, I think it may just be very heat conductive, so even medium hot is able to burn, almost like touching metal.The camera doesn't get too hot but the SD card is burny hot. Glad I bought Endurance SD![]()
If anyone has a Heat Gun Sensor handy try the following :The camera doesn't get too hot but the SD card is burny hot. Glad I bought Endurance SD![]()
If you make it a USB-A to USB-C cable, rather than C to A! That is, A at the power source end.Will a standard USB-C to USB-A 3.0 charge+sync phone cable rated for 3 Amps power the A139 with 3 cams from indoor phone charger or 2.4 Amp powerbank ?
You had better go back and test the 64GB again at the end, to check the value, since the camera will take a lot more than 5 minutes to warm up to a stable temperature inside, and that will affect the results.If anyone has a Heat Gun Sensor handy try the following :
insert 64 GB micro SD memory card and record in Parking Lot for 5 mins then aim sensor at card slot
repeat with 128 GB card or 256 GB ... be amazed at the difference.
What is the difference?If anyone has a Heat Gun Sensor handy try the following :
higher capacity storage size memory cards (chip density) get hotter...What is the difference?
