The lukas is 12 V, all of them i think, or have that changed with the newer dual cams ???
I have a "plan" to run my 5 port USB power supply with one of the lipo batteries i have for my HID torch, i think you can allso draw power on the same barrel plug as you use when charging them.
If its 12 V you can power it of somthing like this
https://www.ebay.com/itm/301776949619
Make sure to get a proper lipo charger for your battery, any old charger you might have lying around wont cut it, unless you want to set fire to your new battery.
EDIT : Just noticed charger is included with this battery, if you go for this or simmilar contact seller to make sure battery have discharge protection build in, was not able to see that with this battery.
Just make sure battery have a discharge protection unit, if you discharge lipo batteries below 3.0 V on each cell you damage them.
This is a small HID torch battery, but you can see the charge port barrel connector on the left side.
Just did the search thing the Lukas LK 7950 is 10 - 24 V input voltage.
- Input Voltage: 10v to 24v
- Operating Temperature: -30 to +70C
- Size/Weight - UV Filter Built in GPS: Front Camera 109x99x38mm 161g Rear Camera 50x26x31mm 25g
- Video Compression: H.264 (High Profile), AVI Format
- Current Consumption: 370mA (13.4V) within Approx. 4.9W (with GPS + WiFi)
- Storage Medium: SD 8GB + microSD 8GB Standard (Max 256GB SD + 256GB microSD)
- WiFi: 802.11 b/g/n/ (2.4-2.4835 GHz)
