I just moved over to a Koonlung K1S and so I don't need this anymore.
It's the G90 A7LA70 with GPS, updated to the latest firmware.
It has worked well for me but keep in mind if you live in a hot climate this thing doesn't like being left attached to the car in the sun, so it is not great if you want a permanent install unless you plan on doing a capacitor mod to it.
It comes with the GPS attachment and the mount, all in excellent condition.
I also have a hardwire kit I can include that comes with enough cable for a rear mounted dashcam as well, and an auto cutoff switch to not drain your battery. It has the mini fuses already wired in, so all you need to do is plug it into your fusebox and attach it to a ground.
That will be an extra $20 as I had to wire the thing up myself.
