Haven't been around lately, but I haven't forgotten you guys
I have been playing with some IR cameras to watch around the yard mostly and the Foxeer and new Owl camera are great for low light or when using Aux IR illumination.
But, the G1W still has some uses.
A couple times a year I go to a 'long range' shoot (only 450 yards) and use the G1W, Video out to a wireless transmitter, a receiver and small monitor. I set up the camera about 50 yards from the 450 yard line and the receiver/monitor at the shooting line. With the Video sent to the transmitter, the G1W still records. Monitor blanks, but it still records.
I have a 800mm f8.0 mirror lens coming and thought about viewing from the shooting line through the G1W, 800mm lens, HDMI output to a 13 inch HD monitor.
The 800mm lens and a crop factor of about 7 for the G1W sensor, would give me about 115 magnification. f8 aperture shouldn't be a problem in full daylight.
Might have enough resolution to actually see bullet holes in the paper 450 yards away. Maybe, might. Might not
Takes a pricey spotting scope to see little holes in the black of a target at that range.
So, here's the rub. The G1W, while it will record AND output VGA video, will NOT record AND output through the HDMI connector. I can view HD on the monitor, OR record HD and view VGA on the monitor. It would be nice to both view HD to sight in with AND record for playback later. But it won't do both.
I could add on a separate HD recorder but that adds cost and battery drain for a portable setup.
The lens should be here in a few days. 800mm on a 1/3 inch sensor. WOW
Looks like I will have to switch cables. Plug in the HDMI cable for HD view during sight in, swap out to VGA cable for HD record/VGA view for record shots.
I'll post some pics when the stuff gets here and I have the chance to play with it.
Later,
RV
