jaronk2000
So I have been researching dash cam batteries, and have found that the reason you need a dash cam specific battery is that it uses Lithium Iron Phosphate (LiFePo4) instead of Lithium Ion. Which is why it does well in extreme temps, holds more charge, charges faster, etc, etc.
I have found some LiFePo4 batteries that are much larger than the typical dash cam specific batteries for around the same price. Would something like this do the same thing? It has 256 Watt Hours instead of 78, and is around $50-100 cheaper than all of the other batteries.
I can't find anything that would make this a bad idea. It can connect and charge via the car port and using adapters you could easily hook up all the dash cams. I know it is significantly larger, but you could put it under a seat, or in the trunk.
Thank you for your help!
