Using this camera on concert
Thomas.Mk
Singapore
Hi guys, recently I used this camera (yi action camera v1.2.13) on the concert and the video exposure I got was horrible (due to the concert light which caused unable to see the artist face at all), any idea how does this can be solved? I do read some of the script posted in the forum but I not sure which one is appropriate, please advice. Thank you!
Could you provide a sample (screenshot) from your video?
Sure, as attached is some of the screenshot of the video. I using the highest setting which the camera offered.
If you know how to use scripts you can use this command:
Code:
t ia2 -adj ae 64
It will do -1EV correction lowering ISO and raising shutter value.
And you can also adjust highlight clipping by this:
Code:
t ia2 -adj autoknee 255
It will add more details in bright areas.
I'm new to this topic (modding stuff), do you have any relevant link for me to take a look?
You can check my blog to get the idea of using scripts from practic examples.
Thank you so much! so the code you mentioned can be stored in autoexec.ash and it will served as auotrun script?
Yes. Those are commands which can be run from a script. Use Notepad++ or similar software to create/edit script files.
