markm75
I know this is a bit of a toss up here. I've installed the dashcam system in our 2015 sorento without much issue. The debate here is that the rear view through the window on the inside is, well, the same as the rear view mirror, naturally. The rear view is tinted, so due to this i'm not getting a bright image. With the gate up, if i aim it in the clear, the image is of course night and day. The trick would be moving it to the outside however.
So from others experiences, have you ended up moving it to the outside? My concern there is that the camera will become obstructed with dirt at times, making the "rear view" (lcd view) useless at times. Of course in that situation you can just hit the button on the bottom and the mirror is a mirror again (i think the front still records?).
Curious what others ended up doing, you dont see many videos touching on the rear aspect to this system (or others with the option of being outside or inside).
Thanks in advance
Thanks in advance
