What is a Circular Polarizing Lens (CPL) Filter?
A CPL (circular polarizing lens) filter is a lens that you can improve your dash cam video quality by reducing lens flares, glare, and reflection that significantly impact the quality of footage details, like license plates and vehicle models. Eliminate these issues caused by moments of extreme brightness by quickly installing the Vantrue’s Circular Polarizing (CPL) Filter. Then you can reduce glare and increase the quality of your E1 or E2 dash cam footage.
These filters work best when outdoor lighting conditions are at their worst. For example, the sun rises, causing the dashboard to reflect on the inside of the windshield. Polarizing filters can also help reduce glare when facing the sun directly. Check out our comparison footage below, showing the same scene with and without the filter on the dashboard.
Vantrue 40mm CPL Filter Features On
Note: This 40mm CPL filter is used for the Vantrue E1 dash cam and E2 front lens. Note: It doesn't work for other Vantrue dash cams.
Adjustable and Slideable
With the Vantrue CPL Filter, you can rotate the ring to adjust the intensity of the filtering effect. This way, you can find a setting that will work best for you in all situations.
Tips: Tear off the protective film and ensure there is no dust on the camera's lens or both sides of the CPL filter. You can remove dust using scotch tape.
- It can effectively reduce reflections, enhance contrast and boost saturation while retaining neutral color rendition in all your shots.
- Aluminum alloy CNC non-slip design, easy to install and remove.
- The super slim 5.5mm rim profile greatly avoids vignettes on wide-angle lenses.
- Multi-resistant coating, anti-scratch, anti-fingerprint, anti-static, oil-resistant, and water-resistant.
