Vantrue E1 Pro Review — 4K Compact Powerhouse with Smart Features and Practical Design LN
LateralNW
VArious
Vantrue E1 Pro Review ​
Update:10 Oct 2025
The E1Pro now supports 1TB memory cards. (Not verified by me personally.) (I don't have that size memory card.)
Many other later models also claim this ability.
*Waiver
Information in this review was correct when originally published.
Check Vantrue.com for updates.
Vantrue supplied this unit for my review — thank you.​
The Vantrue E1 Pro is a feature-rich, compact dash cam offering true 4K resolution and thoughtful design details
that make it a compelling choice for drivers who want premium video recording without the bulk. This unit
impressed me in several key areas while leaving room for improvement in others.
📹 4K Resolution at its Core​
At its core, the E1 Pro delivers 4K (3840×2160) resolution powered by a Sony image sensor.
Daylight footage is sharp and colour-balanced, with reliable exposure control even in high-contrast scenes.
Thanks to the Vantrue PixePlate technology, night-time clarity gets a boost — but with caveats.
While PixePlate appears to slightly darken the image, the trade-off is better licence plate capture.
It’s not perfect, and it doesn’t always catch every plate, but it’s a step in the right direction for night performance.
During night-time driving on mountain roads, the footage took on a green tinge, which
may be related to how the camera processes low-light scenes in certain conditions.
It doesn’t ruin the video but is worth noting for those who frequently drive at night in remote or rural areas.
In night driving tests, under the firmware version used during this review, there was a slight “urging” or
micro-jitter in some clips — barely noticeable but worth mentioning. This could very well be ironed out in future firmware updates.
💾 Micro SD support to 512GB​
The unit supports microSD cards up to 512 GB, but the supplied Vantrue 128 GB U3 V30 A2 microSD card performed reliably.
With fast write speeds and endurance suitable for continuous loop recording, this card is clearly chosen to avoid the
common pitfalls users face when pairing dash cams with lower-grade storage.
📏 Compact design​
Measuring just 72 mm wide and 51 mm tall, the E1 Pro is one of the most compact dash cams in its class.
It blends discreetly into the windscreen area, avoiding driver distraction. Its high-quality 1.54-inch IPS screen (non-touch)
offers crisp, vibrant feedback for framing, reviewing footage, and navigating settings.
🧲 Updated Magnetic Connector​
The mount uses Vantrue’s updated 4-pin magnetic system, which ensures a secure connection with easy removal.
Adjusting the camera to suit different windscreen angles is straightforward, and the screw-in CPL filter plays a critical role here.
🔲 CPL Filter easy to adjust​
The included large circular polarising filter (CPL) stands out. It’s not only useful for reducing glare and reflections
off dashboards and windscreens but also beautifully designed. You can adjust it with one hand, even while the
camera is mounted, making it one of the most practical CPL implementations on the market.
🎛️ Navigating the E1 Pro​
Navigating the E1 Pro is done via a set of physical push buttons below the screen. There’s no touchscreen, but the UI is
intuitive, and the screen's sharpness helps in reading menus easily. Voice control is another standout — the
E1 Pro supports commands like:
  • “Turn on screen”
  • “Lock video”
  • “Take photo”
  • “Turn on/off audio”
These worked reliably during the test period, even in noisy car environments.
After the initial setup voice recognition didn't work which required the use of the app to
set the Activate voice recognition to ON. (Was a problem is earlier models but intermittent so they added this option.)
⚡ Power Adapter​
Vantrue includes a cigarette lighter power adapter with an additional USB-A port rated at 5 V / 2.4 A,
which is great for charging a phone or GPS simultaneously. The attached USB-C power cable is a generous 3.5 m long,
offering enough length for tidy, concealed routing around most vehicle cabins.
🌐 Over The Air Updates so Easy​
The Vantrue app allows basic settings adjustments and live view streaming. However, setting HDR mode
timing via the app
proved awkward, and the HDR toggle didn’t always respond — likely a minor bug
that can be fixed with an app update.
Where Vantrue shines is with over-the-air (OTA) firmware updates. They were seamless and fast — genuinely one of the best OTA
update experiences in dash cams today. Unfortunately, updates reset some settings, notably
language and GPS region (e.g., London, Sydney, New York). However, time and date stamps remain intact,
and GPS re-locks quickly once the correct region is set again.
🕓 GPS on Screen Speed​
The E1 Pro displays the vehicle’s speed in the bottom-right corner of the screen
when GPS is active. It’s a helpful feature, but the font size could be slightly larger to benefit drivers with limited
vision, especially in bright sunlight or quick glances.
✅ My Thoughts​
The Vantrue E1 Pro is a well-rounded, thoughtfully engineered dash cam. Its strong video quality, compact form,
well-designed CPL filter with its easy adjustment, and OTA update capability make it a solid option for those seeking a
dependable 4K dash cam. While the app could benefit from minor usability improvements and night footage has a
few quirks, the overall package is well-executed.
Special thanks again to Vantrue for supplying the E1 Pro and 128GB high-endurance microSD card for this review.
Here’s a video comparing three dash cams: the Vantrue E1 Pro, the Viofo A329, and the 70mai X800 (also known as the 4K Omni).
This road is closer than the one I used before, where I had to drive for 30 minutes to reach my preferred testing area. It’s also less damaging to my car’s suspension.
Anyone know why the E1 Pro colour seems like it has a greenish tinge?
It does have the CPL filter on.
A329, E1 Pro, X800 4K Omni, Night drive comparison including audio test
Check out these two videos:
  • The first video demonstrates how straightforward it is to upgrade the firmware of the Vantrue E1 Pro using the over-the-air method.
Vantrue 4K E1 Pro Simple Firmware upgrade using over the air OTA
  • The second video showcases daytime footage of the E1 Pro's performance on dirt roads, handling vibration, and later on bitumen roads in a country setting. In this video it is also a comparison with the 70mai X800.
X800 compared to the E1Pro Daytime footage county roads Vanture 70mai
Another release!
No explanation.
"Fix Known bugs"
One comment said the last update broke their wifi!
With the latest Vantrue software I'm unable to connect to the E1Pro with my iPhone 8.
Ver 1.0.49 for IOS 28th Sep 2025.
@Jeff_Vantrue any idea why? *Note I've turn on the permissions it requested.
Could you please try restarting your phone, then either enabling Airplane Mode or turning off cellular data before connecting again? Sometimes that helps the connection.
Hi Jeff thanks for the suggestions.
The only thing i hadnt tried was putting the phone in airplane mode.
Once in this mode the E1Pro connected without any errors.
Will this problem be fixed?
Thanks again.
Thanks again.
Thanks for the update! We’ll continue to optimize the app connection experience to make it more stable and user-friendly in future updates.
The E1 Pro supports micro SD cards up to 1TB, offering plenty of space for all your recordings.
Thanks.
I'll update my specs.
I'm pretty sure on release it had a max of 512GB as did the other units at the time.
Ironically the price of the 1TB memory card is almost the price of the E1Pro.
Firmware update for the E1Pro 4K
While the release date says 21- Oct 25
The log may have been updated / missing on the .net site.
@Jeff_Vantrue please advise. Thanks.
  • Release time: 2025-10-21 11:26:04
Version number E1PRO_VT-EEJ151
The log fixes
Update Log
I don't see any.
Link to Log on other site. vantrue.com
Source. Note no log is listed on this site. ATP.
The log fixes
Update Log
I don't see any.
Changelog is listed for all Vantrue models now on the .com website , as the .net website is slowly phased out.
The log fixes
Update Log
I don't see any.
Thanks for your attention! We’ve decided to gradually phase out the Vantrue.net website and will be focusing on Vantrue.com moving forward.
Here is short video of the Vanture E1Pro vs the Viofo A119MPro
Depending on the day they seem to be similarly priced.
These are both great cameras - I really love how small and unobtrusive they are and their great image quality. I've recommended them to many friends and co-workers that are looking for lower priced cameras. Tuck them behind the rear view mirror and then forget about them... 🙂
