Vantrue E360 'Ace' (unboxing & first impressions) (Novatek NT98530, dual Sony Starvis 2 IMX675/IMX335 rear, GPS + 5GHz Wi-Fi, HDR, dual 2.7K)
Augustus
Perth, Australia
Viofo, Vantrue, 70mai, Wolfbox, DDPAI
Back again this week with another dashcam unboxing, with a first for me, a 360 degree dashcam - the Vantrue E360 @Jeff_Vantrue . For my review purposes, I have the Ace bundle which includes additional accessories in addition to the E360 - namely a tripod / selfie stick with enclosed 18650-type battery. This enables up to four hours recording on it's own. Back to the E360 itself, this utilises the tried and true Sony Starvis 2 IMX675 sensor, on both the front and rear of the unit itself. This gives it the possibility to capture stitched 360 degree footage, in both the car and handheld modes (when using the selfie-stick mount). Rounding out the camera sensor package is the rear camera unit, which uses the older (but still decent) Sony IMX335. I also received the VP05 hardware kit, and 512GB Vantrue-branded microSD card (more on that later).
When it comes to the retail box contents, there is a quite the extensive packing list (get ready for this). There is the dashcam itself, rear dashcam unit, rear dashcam cabling, a protective soft-fibre touch sleeve, car mount, selfie-stick mount (with included 2x Panasonic 18650 batteries), fold-out legs tripod, plastic pry tool, integrated car charger (with spare USB-A port), spare adhesive mounts for front and rear units, adhesive clips for dashcam cabling, USB-C to USB-C cable, electrostatic mounting stickers, and soft touch microfibre cloth for cleaning. Phew, that's quite the list!
First impressions of the Vantrue E360 with it's 1.54 inch touch screen are very positive. The build quality is the typical sturdy that we have come to expect from an established dashcam player such as Vantrue. There are warning stickers on the dashcam and on the box to be careful, as the dashcam itself can become quite hot in charging / recording. The unit isn't very heavy in hand but isn't too light either to be easily misplaced. The car mount and selfie-stick mounts click in satisfyingly and safely.
Installation of the E360 was once again a relatively straightforward matter, and the inclusion of adhesive clips for the cabling is most welcome (and something that we don't see very often). Connection to the Vantrue app was also seamless, and out of the box I had to perform a firmware upgrade. The latest version as of my testing is VT-EDK271, dated December 2024. We have a lot to dig through with the E360 as it has multiple recording modes - panoramic (stitching the dual 2.7K lenses together), dual fish-eye etc. Stay tuned for my full review, coming up soon here on DashCamTalk.
Some close-up photos of the Vantrue E360 dashcam:
Ran some benchmarks with the 512GB Vantrue-branded microSD memory card. Thank you to @Nigel , as my initial results yielded test speeds that were 2.5x - 3x lower than the below stated results for some strange unknown reason. I formatted the memory card in-camera but that did not fix the speeds, so used the SD Association Formatter recommended by Nigel which gave the results below. These results appear to be in line with other own-branded memory cards from competitors such as 70mai and Viofo - while not the fastest microSD memory cards out there, still plenty enough for the 5.2K output we have with the E360.
Screenshots below of the Vantrue app for the E360 dashcam / 360 degree camera. It's not the most basic feature-set out there, but it works fluently and in a very stable fashion. Plenty of options are on offer for the user of the E360, both in Drive Record setup and Handheld Record setup.
Ran some benchmarks with the 512GB Vantrue-branded microSD memory card. Results are definitely not the highest out there, which gives me some pause as it says it's A2 but it's only Class 10 - which may explain why we are seeing low SEQ1M and random write speeds (ideally we are looking for around 2.5x - 3x the speeds on offer here). Other V30 cards have yielded far better write speeds. No matter, this should be sufficient for most users, as we are not recording from 4K image sensors.
View attachment 76900 View attachment 76901
The results seem a little low.
I just tested my Vantrue 256GB card.
My write speeds are 88MB/s
Read 97MB/s
Maybe you can check again
Read 97MB/s
I ran it twice and similar results in the 30s :/
Try slow formatting it with the SD Association SD card formatter, sometime the results are surprising, although if it suddenly speeds up to twice the write speed, it is hard to say what that really means in normal use!
I received the same Vantrue 512GB Endurance Pro card with my E360 test sample.
I tested the card with the supplied Vantrue microSD adapter in the SD reader of my laptop, and I also used a USB3 microSD card reader, with consistent results using both methods.
I think I formatted the card in-camera after updating the firmware, but I'm not 100% certain.
Vantrue microSD adapter:
USB3 Card Reader:
Thank you guys for your input, have updated the results now.
That looks better, wish I knew why yours was initially slow, and what the SD card formatter actually does to speed them up! This is not an uncommon result though.
Vantrue E360 / E360 Ace Firmware Update
  • Release time: 2025-03-13 11:23:37
  • Version: E360_VT-EEC111
  • File size: 96.4M
Changelog:
Major Updates:
  • Updated to the latest IQ, enhancing clarity
  • Added PanoVis stitching mode. Panorama mode now supports centre and left-right stitching, and the dual fisheye mode supports left-right and top-bottom stitching
  • Added Traditional Chinese language support
  • Introduced "Fatigue Driving Reminder" feature
  • Introduced "Overspeed Reminder" feature
  • Added feature for LTE module SD card upgrade, allowing firmware upgrades through the main unit
  • Introduced SIM card data control feature
  • Added APP key feature to prevent third-party apps from connecting to and operating Vantrue devices
  • Added an infrared light option for parking monitor settings, allowing independent control of the infrared light in parking mode
Other Updates:
  • Customer feedback issue: enhanced the parking monitor feature to resolve occasional inability to exit parking monitor mode
  • Resolved the issue where "4G SD card formatting doesn't notify the app upon completion, causing a status mismatch"
  • Improved connection stability and addressed issues with screen flicker and non-display for the rear camera
  • Changed the default date to January 1, 2025
  • Fixed the issue of abnormal display when enabling collision quick start mode and switching from fisheye view in Drive Record to handheld panoramic mode
  • Resolved visual anomalies in handheld mode when returning to the main screen
  • Fixed the issue where "disconnecting the APP manually when viewing photos in the SD card album, causes touch commands to be ineffective upon re-entering the album, preventing returning to the list view"
Just some quick observations regarding the newest firmware update, VT-EEC111:
  • Touchscreen operation on the unit has improved a lot with this newest update. Mis-scrolling and mis-touches are now in the past
  • New "Fatigue Driving Alert", "Speeding Alert", PanoVis stitching modes are contained within the E360 on-board menu itself, not the APP
  • "Fatigue Driving Alert" has options for Off, 2hrs, 3hrs, 4hrs, 5hrs, 6hrs
  • "Speeding Alert" has options for 40km/h, 50km/h, 60km/h, 70km/h, 80km/h, 90km/h, 100km/h, 110km/h
Best cloud camera, I still need to review mine but I don't have much to say other than brilliant.
The biggest drawback for some users will be number plate captures - how much that matters varies from person to person. However it should work well in combination with the single-channel E1 Pro. I intend to do some combo testing of this setup soon.
Just some quick observations on the E360 selfie stick, when it comes to charging.
The selfie stick does charge other devices at a rate of ~13W, while it is charged itself at roughly ~18W. While somewhat slow by today's standards, if you're needing a quick top-up of battery juice, then the selfie stick can act in this way.
There has been some more updates to the Vantrue APP in the Google Play Store:
The latest version is now 2.1.01 and brings the following improvements:
- Modify known bugs
- Optimise the process of activating devices
- Add new APP functions
As you can see in the screenshots below, there is a new Community tab which doesn't have much at the moment but there is a direct Service tab. Also apparent in the app is the new activation process for Vantrue Intelligence, which will be making its debut in the older S1 Pro and the upcoming S1 Pro Max.
  • Release time: 2025-09-15 11:23:37
  • Version: E360_VT-EEI081
  • File size: 96.4M
Changelog:
Important Updates:
  • Added an optimised LTE activation process
  • Optimised power-on behaviour to prevent shutdown when using older car chargers with high wake-up voltage
Other Updates:
  • Fixed an issue where under certain conditions (specific resolution and app operations), the dashcam incorrectly displayed 5.2K recording
  • Fixed an issue where parking mode could not exit after disabling message upload
  • Added Privacy Mode
  • Certification Information updated: UKCA and PSE certifications removed
  • Disabled certain 5G Wi-Fi frequency bands to comply with regional regulations
  • Added abnormal wake-up handling logic
  • Updated partial translations
Still using mine, excellent for all around parking.
Nice, I wish I could say the same for myself but I prefer the Omni 4K. I understand it's a different approach but it's worked out better for me with the cloud and just picking up plates seems to be better with the 70mai.
I haven't had a chance to try out Vantrue's cloud service, so that might swing it back into my conscience but for now, it's a no from me
I like the Omni 4K too.
My current setup is the E360 and the T800 in the same car. I have the E360 set up for parking mode and don't use the T800 for parking mode. Kind of spoilt for choice.
