LateralNW
- Nov 7, 2016
- Australia
- VArious
The Vantrue E360 isn’t just a dashcam — you can actually take it out of your car and use it handheld, kind of like a 360° action cam. It works with an optional selfie stick-style handle that has its own built-in battery, so you get around 4 hours of use on a full charge without needing to plug it in.
The camera connects to the handheld grip using a threaded screw mount — the same kind of system used to attach DSLR cameras to tripods. That standard 1/4"-20 thread has been around since the early days of photography in the 1800s and is still the go-to for solid, reliable mounting. So when you’re walking around shooting handheld footage, you don’t have to worry about it coming loose or falling off.
It’s a neat little bonus if you’re already using the E360 in your car, and then want to grab it and start filming handheld without switching to another camera.
And here's a hidden trick — when you're not using the charging port to charge the Selfie Stick Handle, you can actually use it to charge your phone. Super handy if you're low on battery and already holding the grip.
Even better, the bottom of the handgrip also has a standard 1/4" thread, which means you can attach the included tripod to it — just like I show in the YouTube video. So you’re not locked into handheld mode — you can set it down and keep filming from a stable surface whenever you need.
This video will give the uninitiated an idea of what the Vantrue E360 can do.
@Jeff_Vantrue
@Jeff_Vantrue
