Julian23
- Nov 16, 2016
- Germany
- Several brands :)
I was recently sent Vantrue’s new Nexus 4 Pro S (N4 Pro S) triple-channel dashcam to check out.
Specs:
Given these specs, I expect the N4 Pro S to be a nice upgrade over the N4 Pro that has been around for some time and had issues with the rear camera.
The N4 Pro S supports microSD cards up to 1 TB and is also compatible with Vantrue’s optional LTE module, LT01, for cloud features (live view, alerts, etc.).
Like other Vantrue cams, the Nexus 4 Pro S uses a supercapacitor (not a battery), so it can safely survive heat and provides a few seconds of runtime after power is cut. The N4 Pro has been very reliable with heat.
Unboxing
The Nexus 4 Pro S packaging is similar to the packaging we saw in the last few years. We see much cardboard instead of plastic. Everything inside, the cameras, cables, and mounts are snugly held in place. The box includes the main dashcam unit (with built-in interior camera), a waterproof rear camera module, the power supply, mounting brackets with 3M adhesive pads, and quick-start guides.
Everything that is included:
The camera and mount
The rear camera
Main unit:
More in the next post!
Specs:
- 3-channel HDR Clear Recording
- Triple STARVIS 2 Sensor
- Exclusive PlatePix™ Technology
- Compatible with LTE Module (LT01)
- IP67 Water-resistance for the rear camera
- 5GHz WiFi
- Smart Voice Control
- 24/7 Parking Mode
- Built-in Dual-Sys. GPS Logger
- Front camera: 3840x2160P 30fps
- Cabin Camera: 1920x1080P 30fps (with Automatic IR LED that can be disabled in the menu)
- Rear Camera: 2592x1440PP 30fps
Unboxing
The rear camera
Main unit:
