Julian23
- Nov 16, 2016
- Germany
- Several brands :)
I was recently sent Vantrue’s new Nexus 4S (N4S) triple-channel dashcam to check out.
Specs:
Given these specs, I expect the N4S to be a nice upgrade to the E3 that has been around for some time. But now with Starvis 2 and the clarity-boosting PlatePix technology, known from the recent releases, to improve the plate capture.
The N4S supports microSD cards up to 1 TB and is also compatible with Vantrue’s optional LTE module, LT01, for cloud features (live view, alerts, etc.).
Like other Vantrue cams, the Nexus 4S uses a supercapacitor (not a battery), so it can safely survive heat and provides a few seconds of runtime after power is cut.
Unboxing
The Nexus 4S packaging is similar to the packaging we saw in the last few years. We see much cardboard instead of plastic. Everything inside, the cameras, cables, and mounts are snugly held in place. The box includes the main dashcam unit (with built-in interior camera), a waterproof rear camera module, the power supply, mounting brackets with 3M adhesive pads, and quick-start guides.
Everything that is included:
The camera and mount
Rear camera and rear camera cable, power supply and mount for rear camera
The rear camera
Double hinge mount for the rear camera
Single hinge mount for the rear camera and spare sticky pad
The new power supply. It will supply 5V 3A to the camera.
More in the next post!
Specs:
- 3-channel HDR Clear Recording
- Triple STARVIS 2 IMX675 CMOS Sensor
- Exclusive PlatePix™ Technology
- Compatible with LTE Module (LT01)
- IP67 Water-resistance for the rear camera
- 5GHz WiFi
- Smart Voice Control
- 24/7 Parking Mode
- Built-in Dual-Sys. GPS Logger
- Front camera only: 2592×1944P @30 FPS
- Front + Cabin: 2592×1944P + 2592×1944P @30 FPS
- Front + Cabin + Rear: 2592×1944P (front) + 2592×1440P (cabin) + 2592×1440P (rear) @30 FPS
Unboxing
The rear camera
