Julian23
- Nov 16, 2016
- Germany
- Several brands :)
Vantrue has been releasing quite a few interesting cameras lately, but the Pilot 2 is something completely different.
I recently received the new Pilot 2 Full System from Vantrue for testing, together with a microSD card, CPL filter, and the VP-05(2) hardwire kit. Big thanks to the Vantrue team for giving me the opportunity to test this setup!
Instead of being just another multi-channel dashcam, the Pilot 2 combines a traditional front, cabin, and rear camera setup with a separate thermal imaging camera.
The thermal camera is obviously the most interesting part. It is designed to detect vehicles, pedestrians, cyclists, animals, and other heat sources even when there is very little visible light available. Combined with AI-based recognition and warnings, the Pilot 2 is intended to work as an additional driver assistance system rather than only recording what happens.
The Pilot 2 also comes with a large 6.25-inch IPS touchscreen and supports Apple CarPlay and Android Auto.
I have the Full System, which includes both the normal dashcam system and the thermal camera system.
For now, I will focus on the unboxing, hardware, installation, and initial setup. Video quality, thermal performance, AI detection, parking mode, and real-world testing will follow later.
Specifications
4-Channel System:
Thermal Camera: (According to the Pilot 2 manual)
Unboxing
The Full System comes with quite a lot of hardware:
Opening the main package:
The Pilot 2 itself is securely stored inside the box.
The 6.25-inch display makes the Pilot 2 considerably different from a traditional dashcam. The screen is large enough to be used for the thermal view, camera controls, and CarPlay or Android Auto without everything feeling cramped.
Rear view of the main unit:
The back of the unit has plenty of ventilation. Considering that the Pilot 2 has to handle multiple cameras, a large display, Wi-Fi, and the thermal system, proper heat dissipation will be important.
The cabin camera is integrated into the main unit, requiring only one cable from the display.
There is also an orange physical button on the main unit. One of its useful functions is turning the display off completely. Pressing it again, using the physical controls, or touching the display wakes the screen back up.
This is a nice feature if you do not want a large screen glowing in front of you all the time.
The Pilot 2 also has an ambient light sensor in the front camera that automatically adjusts the display brightness depending on the surrounding light conditions.
Everything included with the Full System:
There is a lot of hardware here, but the whole package feels extremely complete and high quality.
The Full System includes the Pilot 2 main unit, front camera, rear camera, thermal camera, the required mounts, and all necessary connection cables. Apart from a microSD card, you basically have everything needed for the installation.
This is definitely not going to be as quick to install as a basic two-channel dashcam, but that is expected considering what the system is designed to do.
More in the next post!
Specifications
4-Channel System:
- Front Camera
- Cabin Camera
- Rear Camera
- Thermal Camera
- Front: Sony STARVIS 2 IMX675, 5MP
- Cabin: Sony STARVIS 2 IMX662, 2MP
- Rear: Sony STARVIS 2 IMX675, 5MP
- Thermal: 12µm WLP high-performance Vanadium Oxide uncooled infrared detector
- Front: 2560 x 1440P @ 30fps
- Cabin: 1920 x 1080P @ 30fps
- Rear: 2560 x 1440P @ 30fps
- Thermal: Unknown - (Video output resolution : 1024 x 768P @ 30fps)
- Front: 158°
- Cabin: 160°
- Rear: 165°
- Thermal: 60°
- Front: F1.8
- Cabin: F2.0
- Rear: F1.8
- Thermal: F1.2
- 6.25-inch IPS touchscreen
- Apple CarPlay
- Android Auto
- Automatic brightness adjustment
- HDR
- PlatePix
- 4 infrared LEDs for the cabin camera
- 2.4GHz / 5GHz Wi-Fi 6
- OTA firmware updates
- Built-in GPS
- 24/7 Parking Mode
- G-Sensor impact detection
- microSD cards up to 1TB
- Supercapacitor
- IP67 waterproof
- Vehicle recognition up to 328 ft / around 100 m
- Pedestrian recognition up to 229.7 ft / around 70 m
- Animal recognition up to 229.7 ft / around 70 m depending on the size of the animal
- DC 5V / 3A
- Operating power: 14W
- -20°C to 60°C
- -25°C to 70°C
Unboxing
