Vantrue S1 Pro Max FIRMWARE (Release time: 12/01/2025)
@Jeff_Vantrue
Good day.
I have a request to make changes to all Vantrue firmware
I would like to use it in 4K 3840*1600 (2.40:1 / 21:9), and also have a format in 2K 2560*1080 (2.40:1 / 21:9).
In this case, an unimportant part of the sky and part of the hood of the car are cut off, the video quality does not suffer and we get a wide format.
@gse and smaller file sizes. I don’t need to see my hood or the sky. Same for the rear camera.
@Jeff_Vantrue
Good day.
Thanks for your suggestion!
Technically, it’s possible to implement, but most users may report black bar issues. Since standard monitors are still mostly in 16:9 format, we've already received similar feedback about black bars with our 1944P resolution.
We'll definitely take your suggestion into consideration, but we’ll need to evaluate it further based on broader user needs and compatibility.
Good afternoon, users should have a choice in the menu and then there will be no problem.
Vantrue S1 Pro Max Dash Cam Firmware Update​
  • Release time: 2025-06-27 11:23:37
  • Version: S1PM_VT-EEF243
Update Log
S1PM_VT-EEF243 (New)
  1. 1. Added compatibility with the RC09 rear camera for the S1 PRO MAX 4K+2.5K model.
    2. Added compatibility with optional DMS (Driver Monitoring System) camera RC08.
    3. Improved the Vantrue Intelligence algorithm for enhanced performance.
  • Release time: 2025-08-13 11:20:38
  • Version: S1PM_VT-EEH071
1.Important Update: Added a Entry/Exit Mode in Parking settings with three settings: Auto, ACC, and G-Sensor. (Note: If the ACC wire was previously connected incorrectly, please select the G-Sensor option; otherwise, Parking Mode will not function properly.)
2. Important Update: Modified the default ADAS settings. Specifically: ADAS retains only Forward Collision Warning and Pedestrian Detection ; BSD retains only Rear Collision Warning; DMS retains only Fatigue Warning; all other detection functions are set to “Off” by default.
3. Important Update: Added Turkish and Czech language options to the main unit.
4. Fixed the translation for 'Privacy Mode' in Russian.
5. Updated other Russian translations with corrected wording.
6. All 3840×2160P resolutions have been updated to display as 4K.
7. In Parking Mode, all collision event videos are now moved to the Event folder.
8. Blocked certain 5G Wi-Fi frequency bands to comply with regulations in specific regions.
9. Removed UKCA and PSE certifications based on the latest compliance requirements.
10. Optimized the logic linking the PlatePix and HDR timers, and added related prompt messages.
11. Added a prompt message when enabling Privacy Mode.
12. Adapted support for the RC08 DMS camera lens, adding an infrared light control option and related prompts.
Firmware Update
Release time: 09/22/2025
Download
Version: S1PM_VT-EEI121​
1. Important Update: Optimized the LTE module activation process and improved LTE connection stability.
2. Optimized the display position of watermark elements (coordinates and speed) at certain resolutions.
3. Corrected the Japanese translation for parking mode enter/exit.
I updated, after a day camera hang (crash), had to force restart. LTE module are still unable to reach (connect) the camera. Reboot both lte module and camera didn't help. 😟
Sorry to hear about the issue. Could you please contact our support team directly regarding this problem? They’ll be able to assist you further: support@vantrue.net
Firmware Update
Download
Version: S1PM_VT-EEK241​
1. Major Update: Optimized IQ performance and increased video bitrate.
2. Optimized the display issue of video download time in the app..
3. Improved the connection stability between the DMS camera and the main unit.
4. Corrected several Spanish translations.
5. Enhanced the Vantrue intelligent algorithm for more stable recording performance.
6. Optimized the loop recording mechanism.
7. Improved rear-view image clarity during app preview.
8. Refined the display of the rear-camera watermark.
Firmware Update
Download
Version: RC11_VT-EEI261​
Awesome! Time for another set of image comparisons, now I just have to find the time 🙂
The front bitrate appears to have increased from 25Mbps to 32Mbps. The rear is unchanged at 24Mbps.
i hope the rear change to 32also
can u advise vantrue change the rear to 32
that is sony 678 carema
how can use so low bitrate
I think the rear camera looks OK at 24Mbps
