Veckle 0906 grainy video
HarrisonHill
I'm not sure if this is expected quality from this camera, but video quality is too grainy. This is more or less fine during the day, but at night it is grainy to a point where you can't distinguish any plate numbers.
Day image:
Day image 2
Night image
Night image 2
Camera was set to 1080p60FPS (same with 30FPS). Quality - Fine (super fine was the same and normal quality was too bad)
Is this expected?
Nigel
Wales
Gitup F1+G3ꞈꞈꞈꞈꞈ Viofo A229ꞈꞈꞈꞈꞈ Blueskysea B4K
It does look a bit noisy at night, but it is hard to tell what the light level is and it may be cause by your video player.
What video player are you using? And can you try a different one?
At night it does have the gain turned up quite high to avoid motion blur, notice that the white lines on the road in your night image have very little blur in the gaps even though you are doing 47kph in the dark, most cameras would have the lines joined together by motion blur in the gaps!
BRex
Hungary
Mini 903; Mini 906
I have the same issues with FIRMWARE_20170829. Before, I did not notice it. It is randomly happening, only in low light conditions.
It is not related to the viewer/player I guess, because it is same in LAN player, Registrator Viewer, rdCAMPlayer, DashcamViewer and in Movavi too
Den-den
Philippines
Yi Dash Cam, Mini 0906
Has the grainy night video been resolved?
I'm experiencing the same.
Playing the video on my Huawei P9. Same result using native video player, vlc player and MX player
