Vico Opia 2 problem
ics
Romania
2xOpia 2 ex: Vico TF2/TF2+/SF2/Marcus 1/Marcus 3/Marcus 4
I have this problem with both of my Vico Opia 2 dashcams. Is there anyone else who has this problem? (fw vers. 2.4G, but it keep doing this in all of the firmware versions)
I think this is because of white balance. If it is not happening many times in a short period should be no problem. I expect that approaching to a smaller car into the same conditions will not change the white balance right there, but maybe later on the road. I bet the white balance was modified because of big truck in front of you.
At the start of the video I saw some LEDs blinking, does Opia 2 have frequency setting to put it on 50Hz to see if that lights will stop flickering? Maybe will help white balance too.
enjoy,
Mtz
@Mtz do you have an Opia 2? I asked if other Opia2 users have this problem. When is low light the image is with a lot of noise.
So, please, if you don't have an Opia2, don't answer. If you have an Opia2, check you recordings and you'll see what i am talking about.
