VicoTF2+ High Bitrate edition...
Can you tell me step by step (software that i need and what do i have to do) how did you change the identifier from timestamp?
Can be done also to a Marcus4, too?
This is done in the hex editor. This can be done in Marcus 4 too...
How to do it step by step you can see here: https://yadi.sk/d/-EPB1C8hdcmSH
  • Like
Reactions: ics
great job - can you do that for Vico TF2 EZ ??
How come you changed the holder - was it to stop the focus drifting in heat with the black base or to give you more options with lenses as it's further away so you can use a longer lens module?
Lost focus after work on a sunny day...
Ah this is a great solution to that - I have had too many cameras losing focus like that when they get too hot, this is a great fix :)
That's going to be a nice little camera that one :)
Can you translate to English ? ;)
MOD Firmware VicoTF2 Premium version 5.0
https://yadi.sk/d/fItvVsNIffCKm
-FullHD - 20Mbit Constant Bitrate
-HD - 16Mbit (30FPS), 18Mbit (60FPS) Constant bitrate
RAW Video:
Day - https://yadi.sk/i/zBSYlwtoeDMzB (720Mb)
Night - https://yadi.sk/i/S4LFi8Z4eEWNy (720Mb)
Thnx works like a charm in Vico TF2 EZ ;)
@Falsificator
Hi,
I have same Vico TF2+ Premium camera and currently using Vico's original v5.1i firmware. I couldn't see v6.3 on Vico's website. There is v6.6+CS. Could you please explain why are you using these modified v6.3 firmware over other firmwares? I see that you have also modified v6.6 but you don't use that firmware. What is the reason?
Thank you
@Falsificator
Hi, I have same Vico TF2+ Premium camera and currently using Vico's original v5.1i firmware. I couldn't see v6.3 on Vico's website. There is v6.6+CS. Could you please explain why are you using these modified v6.3 firmware over other firmwares? I see that you have also modified v6.6 but you don't use that firmware. What is the reason? Thank you
Firmware 6.3 has vico-schedule and better contrast and WDR (IMHO).
In the modified firmware higher bitrate and video quality.
Is v6.3 released and then unsupported or is it country specific firmware? Because I didn't know v6.3 existed until I read this thread.
Releases firmware for Russia and other countries differ only in the name of the firmware version.
At the moment, I am aware of these versions of firmware for VicoTF2+: 5.0 - 5.1 - 6.2 (6.3) - 6.6...
