DashSplash
- Aug 1, 2015
- Canada
- Mobius
Hi, At time lapse interval of 0.25 it is going to give you a fps of 4 so why not just set in normal video mode and set the frame rate 5 fps ? This way you will have all the video mode facilities ie short file setting and loop back ?
Just to add ....I have removed the internal battery and installed a Tiney DC step down module with the output set at 4 volts. Now I can run off a external power source of anything between 6 and 26 volts !
Good suggestion. I usually use 0.5s time-lapse video which gives 6 days of recording on a 64Gb memory card. By using 5fps video frame rate, this will go down to about 2.5 days of recording. This is much less but it might be a good compromise considering the fact that it would loop without trouble. I will try it, THANKS A LOT! (FYI, I updated to FW v2.41 and still doesn’t loop with 0.5s time-lapse)
