I have recently bought a M300, software version 1.0.4ww (no update available from 70mai app)
At first I thought I have a bad SD card... the videos are laggy (like they had fps drops) and the sound is off by a few seconds.
It's similar when viewing in 70mai app and same or even worse when downloading to phone (Xiaomi Redmi 9T)
I tried a different card and it was the same, different settings (lower resolution etc) but nothing changed. Then I transferred the video to my Windows 10 PC.
And here it works! Built-in windows video player displays the video perfectly smooth, together with synced audio. Everything's perfect.
VLC on the other hand (which I considered a better player) displays the video smooth, but the audio is completely screwed up. I'm hearing some weird chirping only.
Has anyone experienced such problem? I have seen a few people with similar problems but no solution for this, and it seems like it works for everyone else.
I did a ffprobe on the video file, here's the result:
Code:
ffprobe version N-94664-g0821bc4eee Copyright (c) 2007-2019 the FFmpeg developers
built with gcc 9.1.1 (GCC) 20190807
configuration: --enable-gpl --enable-version3 --enable-sdl2 --enable-fontconfig --enable-gnutls --enable-iconv --enable-libass --enable-libdav1d --enable-libbluray --enable-libfreetype --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenjpeg --enable-libopus --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libtheora --enable-libtwolame --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxml2 --enable-libzimg --enable-lzma --enable-zlib --enable-gmp --enable-libvidstab --enable-libvorbis --enable-libvo-amrwbenc --enable-libmysofa --enable-libspeex --enable-libxvid --enable-libaom --enable-libmfx --enable-amf --enable-ffnvcodec --enable-cuvid --enable-d3d11va --enable-nvenc --enable-nvdec --enable-dxva2 --enable-avisynth --enable-libopenmpt
libavutil 56. 33.100 / 56. 33.100
libavcodec 58. 55.101 / 58. 55.101
libavformat 58. 31.104 / 58. 31.104
libavdevice 58. 9.100 / 58. 9.100
libavfilter 7. 58.101 / 7. 58.101
libswscale 5. 6.100 / 5. 6.100
libswresample 3. 6.100 / 3. 6.100
libpostproc 55. 6.100 / 55. 6.100
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'ori.mp4':
Metadata:
major_brand : isom
minor_version : 512
compatible_brands: isomiso2mp41
encoder : Lavf58.20.100
Duration: 00:02:00.03, start: 0.000000, bitrate: 16772 kb/s
Stream #0:0(und): Video: hevc (Main) (hvc1 / 0x31637668), yuv420p(tv), 2304x1296, 15980 kb/s, 30 fps, 30 tbr, 90k tbn, 30 tbc (default)
Metadata:
handler_name : SStar Video
Stream #0:1(und): Audio: aac (LC) (mp4a / 0x6134706D), 16000 Hz, mono, fltp, 72 kb/s (default)
Metadata:
handler_name : SStar Audio
Stream #0:2(und): Data: none (ssmd / 0x646D7373)
Metadata:
handler_name : SStarMeta
Stream #0:3(und): Data: none (ssmd / 0x646D7373), 0 kb/s
Metadata:
Unsupported codec with id 0 for input stream 2
Unsupported codec with id 0 for input stream 3
