Viofo A119 Mini all parking files locked
mariomart
mariomart
Western Australia
Viofo A119 V3, Viofo A119S V2, Mini0806 and Navman MiVue 530
The event recording also known as buffered recording, the files will be locked by default, this is limited by the chipset solution, we can not change it.
So they will not be overwritten when the SD card is full? So we need to manually delete these parking files?
laumiakys
Vilnius
Lithuania
I think the same situation (automatic parking record locking) applies to the a129 pro.
Yes, there is same problem with my viofo 129 duo pro after the firmware update. All parking videos are locked - and there are no video in the parking folder when l lock via viofo app.
The parking auto event detection should record parking video with movement and lock videos if g-sensor was triggered. At least dashcam behave so before the firmware update…
mariomart
mariomart
Western Australia
Yes, that's exactly what all my previous Viofo cameras did, only lock when G sensor triggered.
mat06
Krakow
Poland
Any news on this topic? Will it really not be overwritten and you have to manually delete the parking files?
mariomart
mariomart
Western Australia
I never received a reply.
Karagandinez
Deutschland
Germany
Viofo A119 V3 / Viofo A119 Mini / Viofo A229 DUO
You can use: "Recording with low bitrate". ;)
mariomart
mariomart
Western Australia
I completely understand that, but why should I?
Previously, the auto event detection function only recorded when it needed to, not ALL the time, so if absolutely nothing happened then no card space was required. It also made it much easier to narrow down the timeline if something did happen, there was no need to scroll through countless hours continuous recording to find the required footage, you just had to check the files with "events".
And when the card needed to free up space it just automatically overwrote the files that were not saved in the RO folder, as it should. But the A119 Mini is apparently not capable of such a minor thing as NOT write protecting EVERY SINGLE FILE!!!
Karagandinez
Deutschland
Germany
I am not campaigning for anyone. Everyone is free to choose which parking mode is more important to him.
I used to also use in the parking lot: "Automatic motion detection" until a certain case.
The car was in the parking lot for 12 hours, during which time 15 cars arrived and left.
A119v3 did not record 5 of them, but recorded how a bird flew by and a leaf moved on a tree.
It's good that the T130 was set to "Record with a low bitrate" and all the events I needed were on the memory card.
Since then, I've only been using "Low Bitrate Recording".
viofo
Shenzhen
China
A129 Pro / A129 Duo / A119 V3 / A119S / G1W-S / WR1/
If the camera supports the buffered recording mode(auto event detection), the files will be locked by default, this is limited by the SDK.
If you don't need the buffered recording, we can disable this feature.
Karagandinez
Deutschland
Germany
If buffered recording does not affect other parking modes, then you do not need to disable it.
Someone really needs it. Let people have a choice.
laumiakys
Vilnius
Lithuania
Ok, but is there possible to program Viofo dashcam that in 'event detection mode' it would lock parking video ONLY if G sensor is triggered and NOT lock but JUST RECORD video if motion was detected and save it in parking folder? Then event detection mode would work as it should be. I believe everybody would agree.
laumiakys
Vilnius
Lithuania
Jordan92028
Fallbrook
Has there been a fix for this? I noticed that my a119 mini is also doing the same thing. All videos that are captured during parked recording are marked as locked.
Jordan92028
Fallbrook
All videos that have motion I should note. It doesn't have to be something hitting the car or anything that extreme. If there is any motion like walking in front of the vehicle it will lock the file.
VIOFO-Support
Shenzhen
China
We have refined our firmware and firmware in different models may also differ, not bug issues. While currently, files under AED parking mode shall be locked, we may have customized firmware that does not lock videos in this mode, you shall then contact us directly by
kalzan
Berlin
Germany
It does not make any sense. Locking files by default for buffered parking mode (mode I decided to purchase the camera for) will cause a card to get full and, eventually, prevent new recordings from being stored!
I also don't remember such behaviour exists in A139, which also has buffered parking mode.
Someone at @VIOFO-Support should finally start thinking!
VIOFO-Support
Shenzhen
China
So, I just did a full factory default/reset. Did a full format on the camera. Set the G sensor to middle sensitivity.
I retested in my garage, by just waving my hand in front of the camera (did not touch anything and did not move the car.)
It's still locking all the parking files.
It must be a bug.
I am using a Samsung Endurance Pro 128gb card which I have been using in my A119 V3 for the last year without issue.
@viofo @VIOFO-Support for your interest.
It seems the camera is working normally, once it detects movement within its range of view, the recording will be started.
