Linophryne
- Apr 11, 2017
- Canada
are you able to do anything with the sounds?
referring to the startup chime and annoying beeps? I've been keeping an eye out for that code area, not sure but it may be possible to add audio sound bytes in a similar way the Logo was changed. Someone else may have located that section but never reported it.are you able to do anything with the sounds?
Creating Custom MODs is becoming easier, pick your preferences, download it from my online Drive (link above). The DICE Logo was added to demonstrate images can be used, and separate MOD'ed from official.are you able to do anything with the sounds?
AUDIO Data Default Modified
Format/Info : AAC : Advanced Audio Codec
Bit rate mode : Variable : Variable
Bit rate : 96.0 kb/s : 112 kb/s
Channel(s) : 1 channel : 1 channel
Channel positions : Front: C : Front: C
Sampling rate : 32.0 kHz : 44.1 kHz
Frame rate : 31.250 FPS : 43.066 FPS
Please take this conversation ELSEWHERE.@BCHobbyist any chance in a near future to adjust a brightness?
can someone tell how much you should increase the brightness to compensate the darkness of the CPL filter? and if you have a CPL + factory tint? it's not that practical to have the CPL filter on or off all the time if the weather outside changes from sunny to cloudy / rainy / dark?
Answer: I'm still searching for Brightness image controls, VIOFO has locked them out of Menu. The only way we can adjust brightness is with EV - Exposure Value, increase it one notch brighter. It will slighting create more motion blurring because its increasing exposure time by letting more light gather. I don't touch it. For the brightest image remove CPL (cover dash with black fabric). I leave my CPL on 24/7 just to protect the lens/sensor from sun even if the image is dimmed slightly.@viofo @BCHobbyist any chance in a near future to adjust a brightness?
thank you!!!!!!!!!!I invite you
Thank you for the footage if you give me permission will be used in next A119 MOD-07&06 promotional video. That is the clearest, sharpest, crisp night video i've seen from A119, and much better than official firmware, can read that large road sign at end from over 10 car lengths away, perfectly focused! Can you repeat route during day with sun overhead or from behind? Viewed that 27.1Mbps footage several times and object definition is shockingly good. Hope to have Saturation, Brightness & Contrast control soon.FWBA119_MOD-06_v3.91+25Mbps+Sharp34+Edge178+DICE.bin
Default settings(per your recommended settings) + CPL
https://drive.google.com/open?id=1-pmb3GCHxxUgdS97JAPjH_53eNVunpfD
Thank you.
@Tractor , Welcome to the DashCamTalk Forum, this place has the most information on almost every Dashcam sold.Other than giving the ability to turn of all beeps, is there any advantage it flashing from FW3.6 to FW3.91?
I have only had the A110 V2 for a few days and still trying out. FW3.6 is the firmware it was delivered with, but I am a little under whelmed by the picture quality. Against my only comparison a YI Smart Dash Cam at 1920x1080 60Fps which is obviously over saturated and sharpen. May be I will try your mods do you suggest a preference at to which one. TIA Tractor
Thank very much for the tips, I will give one of you mods a go in a few days after the newness has worn off, I will let you know how it goes. Thanks Tractor@Tractor , Welcome to the DashCamTalk Forum, this place has the most information on almost every Dashcam sold.
Official Firmware v3.90 & 3.91
Fixed: The random white screen issue. This a another attempt at fixing this bug, as V3.6 did not fix it. Added a Boot Delay to the menu
It would a good idea to update to v3.91 for the 'white screen fix' and Boot Delay option. None of that will change Image Quality so MODs are the only current way to alter them.
In my online MOD archive there is a recommended MOD usually less than 27Mbps, always try that first from the Stable MODs folder. Must RENAME all MOD files to FWBA119.bin for updates.
DOWNLOAD A119 Modified Firmware: https://drive.google.com/open?id=1d47InQ8qHSkZCgVfxersR1gflsd3hQTN
Thanks for sharing, that night clip of you accelerating away from motorcycle is impressive. Any other dashcam wouldn't beable to handle that bike's headlight intensity, its even too much for A119.Both Clips running FWBA119_MOD-07_v3.91+27Mbps+Sharp34+Edge178+DICE
WDR=OFF / EV=0 / 1080p 60fps / 60 hz / NO CPL
Inside of window not exactly clean.
Outside of window sort of clean
Tint Film is 30% SUNTEK with IR blocking.
Blur lines are from the defroster grid.
Vibration is due to the mounting surface is plastic trim around door panel is not super stable.
Clip #1 Is early afternoon.
Clip #2 Is early Morning before sunrise.
B | Viofo A119 V2 Hardwire suddenly stopped working | A119 | 0 | |
C | A119 only shows VIOFO logo on startup. Does not do anything else. | A119 | 6 | |
K | Viofo A119 V2 HK2 or HK3? | A119 | 21 | |
T | Viofo A119 | A119 | 3 | |
T | Viofo A119 | A119 | 7 |
