vvs49
- Jan 8, 2015
- Ukraine
On any firmware, but rarely, there is no system.Does it do it with firmware V1.0 or V1.01?
You try the boot delay?On any firmware, but rarely, there is no system.
post photo with camera opened showing the position of copper shield, yellow layer, ribbon cables and supercapacitors.On any firmware, but rarely, there is no system.
I do not lose the voltage, so the delay is not needed.You try the boot delay?
I don't understand, this?post photo with camera opened showing the position of copper shield, yellow layer, ribbon cables and supercapacitors.
looks the same as my V3I don't understand, this?
OKsuggest you carefully remove the tape from sensor cable ends then reattach both ends fully into locking connector so it ends up looking like this
Savvy dashcam buyers know to wait a few months before purchasing new models, allowing time for kinks, bugs, flaws to be identified and fixed.
Many aren't aware Viofo is about to release another new dashcam model with >stable< 4-clip GPS mount, not the unstable single clip 2016 design. The new A129 Pro has 4K resolution allowing the owner to select 4K or 2K or 1080p and supports optional Rear camera with improved WiFi control. Hopefully the extended Alpha testing phase currently underway solves the brightness issue most 4K sensors have in lower light conditions. I know exactly which offset code to MOD first. The A119/P/S V2 model days are numbered, all Hail the A129
wild guess - given recently discovered issues with advanced parking mode the Pro model will probably be held back until late August or longer.Any idea when the A129 Pro will be out? I did see the bulk order listing on Viofo's website: https://viofo.manufacturer.globalso...5/pdtl/Dash-camera/1166620505/4k-dash-cam.htm
Sounds about right...mine are due next Thusrday..all going well with customs....Sent an email to VIOFO Australia for when A119 V3 will be available in Australia and RRP
Reply - 2 weeks and AU$179
good to see V3 isn't dead.Already a system.
I haven't checked yetdid reconnecting the sensor ribbon cable revive V3 ? or was copper shield shorting out on RTC battery ? or was thin yellow GPS cable the cause ?
V3 startup looks slow in vehicle when powered using custom AV out cable.
on workbench power drain doesn't look normal.
Does the V3 GPS mount cause random startup issues when power cable is connected to mount ?I looked installation, everything is OK there.
I am inclined to believe that the firmware is to blame, why there is never any problem connecting to the USB?
If you enable the 265 codec, 4K resolution appears in the menu
3840x2160_24fps
The truth works terribly, the movie is jerking and the numbers are crawling on each other.
20190713111010_000014.MP4
drive.google.com
So I showed in the film, at home without GPSWhat happens when running A119 V3 with GPS Menu setting disabled ? works normally ?
since the V3 has new GPS chip more testing is needed.So I showed in the film, at home without GPS
The result is the same and does not depend on the method of connection !!
P. S. BCHobbyist!!
Badly understood, do you mean GPS in the menu or hardware?
I forgot, V3 at my house, checked it from the first time does not work!!!OFF GPS in Menu Settings firmware ?
D | Viofo A119 V3 Issue | A119 V3 | 11 | |
R | Viofo A119 V3 HDR/Not HDR, 60fps/30fps, CPL/No CPL | A119 V3 | 21 | |
R | Viofo A119 V3 on special price | A119 V3 | 1 | |
D | Viofo A119 v3 (Firmware 2.6) Stop & Go on Red Lights | A119 V3 | 5 | |
VIOFO A119 V3 no longer recording GPS | A119 V3 | 7 |
