VIOFO A119S (IMX291) & Street Guardian SG9665GC V2 (IMX322)
Harsh
Likes
2,587
Delhi
India
Mobius, A119, Mobius Maxi, A129 Duo
#1
VIOFO A119S (F.W V. 1.0) - 1080p @ 60 FPS, WDR - On, CPL - Yes.
Street Guardian SG9665GC V2 (F.W V. Update 4) - 1080p @ 30 FPS, WDR - On, Metering - Centre, Contrast - Medium, CPL - Yes.
Early evening - 1
A119S
https://drive.google.com/open?id=0B97KXpJ3jAfRV3lhTExRRnFjOVk
SG9665GC V2
https://drive.google.com/open?id=0B97KXpJ3jAfReGVjRHJWdFprakE
Combined
Early evening - 2
A119S
https://drive.google.com/open?id=0B97KXpJ3jAfRQ1hxWjZmX3U5OXc
SG9665GC V2
https://drive.google.com/open?id=0B97KXpJ3jAfRa3d4V3gtTkR4blk
Combined
Evening - 1
A119S
https://drive.google.com/open?id=0B97KXpJ3jAfRT3VveTJKVFJTejg
SG9665GC V2
https://drive.google.com/open?id=0B97KXpJ3jAfRNURnQ0J2am5pNDQ
Combined
H
Harsh
Likes
2,587
Delhi
India
alexsoll
Retailer
Likes
1,256
Minsk
Belarus
Street Guardian, BlackVue, TrendVision
#3
@harsh , thanks for the joint test, but with CPL, did not disclose the full picture of the real definition optics,
and especially in the evening / night
supplement for information:
A119S
Format : MPEG-4
Format profile : Base Media / Version 2
Codec ID : mp42 (mp41/mp42/isom)
File size : 145 MiB
Duration : 1 min
Overall bit rate mode : Variable
Overall bit rate : 20.3 Mb/s
Movie_More : DEMO1
Encoded date : UTC 2017-01-12 15:26:56
Tagged date : UTC 2017-01-12 15:26:58
Origin : NOVATEK
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High@L5.1
Format settings, CABAC : Yes
Format settings, ReFrames : 1 frame
Format settings, GOP : M=1, N=15
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Duration : 1 min
Source duration : 1 min
Bit rate : 20.1 Mb/s
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 60.000 FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.161
Stream size : 144 MiB (99%)
Source stream size : 144 MiB (100%)
Title : Core Media Video
Audio
Format : AAC
Format/Info : Advanced Audio Codec
Format profile : LC
Codec ID : 40
Duration : 1 min
Bit rate mode : Variable
Bit rate : 96.0 kb/s
Channel(s) : 1 channel
Channel positions : Front: C
Sampling rate : 32.0 kHz
Frame rate : 31.250 FPS (1024 spf)
Compression mode : Lossy
Stream size : 703 KiB (0%)
Source stream size : 705 KiB (0%)
Title : Core Media Audio
SG9665GC (V2)
Format : MPEG-4
Format profile : QuickTime
Codec ID : qt 0000.00 (qt )
File size : 110 MiB
Duration : 59 s 998 ms
Overall bit rate : 15.4 Mb/s
Movie_More : Street Guardian
Encoded date : UTC 2017-01-12 15:27:05
Tagged date : UTC 2017-01-12 15:27:06
Writing library : Apple QuickTime
Origin : NVT-IM
Video
Format : AVC
Format profile : High@L4.1
Codec ID : avc1
Bit rate : 14.7 Mb/s
Frame rate : 30.000 FPS
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.237
Stream size : 105 MiB (96%)
Source stream size : 106 MiB (97%)
Language : English
Audio
Format : PCM
Format settings, Endianness : Little
Format settings, Sign : Signed
Codec ID : lpcm
Source duration : 59 s 998 ms
Bit rate mode : Constant
Bit rate : 512 kb/s
Bit depth : 16 bits
Stream size : 3.66 MiB (3%)
Source stream size : 3.66 MiB (3%)
Language : English
Sutton
Likes
228
One SG9665gc.. Two Viofo A119.. Three A119S
alexsoll
Retailer
Likes
1,256
Minsk
Belarus
#5
The A119S is much sharper and much clearer But how can that be
1. Frame rate : 60.000 FPS / 20.3 Mb/s vs 30.000 FPS / 14.7 Mb/s
2. different polarizing filters
3. I see blurry the red stop-lamps of the car, the lens is not very clean
H
Harsh
Likes
2,587
Delhi
India
#6
With most users (me included) leaving the CPL filter attached all the time, comparing them with their respective CPL's felt like a better one to start with.
I'll add videos without a CPL within a few days.
H
Harsh
Likes
2,587
Delhi
India
#7
The lens and windshield were both clean, it's the smog/haze in the air making it look like that, all street lights and car stop-lamps were flaring the same when observed by sticking my head out a bit from the driver's side window.
I don't have the new single glass filter from SG.
Sutton
Likes
228
#8
A119S
Format : MPEG-4
File size : 145 MiB
Duration : 1 min
Movie_More : DEMO1
Origin : NOVATEK
Video
Format : AVC
Codec ID : avc1
Duration : 1 min
Color space : YUV
Bit depth : 8 bits
Audio
Format : AAC
Format profile : LC
Codec ID : 40
Duration : 1 min
SG9665GC (V2)
Format : MPEG-4
File size : 110 MiB
Origin : NVT-IM
Video
Format : AVC
Codec ID : avc1
Color space : YUV
Bit depth : 8 bits
Language : English
Audio
Format : PCM
Codec ID : lpcm
Bit rate : 512 kb/s
Bit depth : 16 bits
Language : English
Your opinion from the above 2 which has better hardware and which one did you like better with the above comparisons.
alexsoll
Retailer
Likes
1,256
Minsk
Belarus
#9
first, distant impression - a worthy model.
need 6-12 months of use, this will display information about the reliability of the device, the manufacturer support, etc.
I hope the manufacturer will always there and ready online to answer users ' questions
Sutton
Likes
228
#10
Thanks for speedy reply
thancam
Retailer
Likes
906
Hà Nội
Viet Nam
too many
#11
Your test have a problem. Your aiming in two camera is not the same. Result of it is: the bright of two image in dark area totaly diffirent.
After quick look in youtube, my conclusion is: 50:50 although bitrate of A119S is much higher than SG. When catching moving object, image of A119S is sharper than SG.
H
Harsh
Likes
2,587
Delhi
India
#12
thancam
Retailer
Likes
906
Hà Nội
Viet Nam
too many
#13
Or maybe focus mode on SG is central, so it focus more on sky. I explain in this pic.
in static scene, it's hard to tell: which one is sharper (in my eyes)
and SG have a larger FOV, which mean everthing in SG will small and less sharp than A119.
Everthing in larger FOV will seems smaller and therefor hard to see than less FOV. But larger FOV has more object than less FOV. This matter was disscussed many time on board.
example:
Reading license plate very easy in this pic.
harder than doing so in this pic,
H
Harsh
Likes
2,587
Delhi
India
#14
I'm using centred metering with the GC, don't know what's been implemented by VIOFO as there's no option for a user selectable metering on V. 1.0 of their firmware.
Mounting of the camera and aiming of the lens was corrected before the videos were recorded. Both are on the 2nd last click of the adjustable lens and the dashboard + bonnet coverage looks identical.
If you have any pointers on mounting and angling it better, please do elaborate, I'll redo it before comparing them without the CPL.
thancam
Retailer
Likes
906
Hà Nội
Viet Nam
too many
#15
You can aim them so they can share the same horizon. And i think Viofo using average AE, you can use the same mode with GC.
TonyM
Likes
1,490
B1W, A129 Duo, Mobius 1 & 2 & Maxi, GitUp F1
#16
The A119S has a wider dynamic range than the SG. Thus in the dark areas the A119 is a bit brighter, whilst in the light areas the A119S is darker. The result is that the SG appears to have more contrast, making some details like number plates easier to read. However the A119S actually preserves more detail with less clipping of the shadows and highlights (where detail is lost to complete black or white). Which is better is down to individual preference.
The increased blur on the SG is due to using a longer exposure time. The more sensitive IMX291 and/or use of higher ISO in the A119S results in a shorter exposure and thus less motion blur. I can't remember if the A119S has a wider aperture lens than the SG.
thancam
Retailer
Likes
906
Hà Nội
Viet Nam
too many
#17
they use the same sensor, so they have the same wide dynamic range.
H
Harsh
Likes
2,587
Delhi
India
#18
I think it's centre from my assessment but that's again speculation. I've tagged Viofo with this question in a different thread, will wait for them to confirm.
They don't. You seem to be confused about the specifications.
thancam
Retailer
Likes
906
Hà Nội
Viet Nam
too many
#19
thanks for reminding me about the specs. :) I was wrong about the specs.
But if two image has diffirent wide dynamic range means: the darker area is brigher and the light area is not overexpose. And in this video, i dont see that.
With EV setting, you can change the brighness of image just like when you use VLC software:
So, if the darker area is brigher, and the light area is nomal. When you use VLC player to increase contract, the light area will not be overexpose. And when that, i shall call A119S or any dashcam have better wide dynamic range.
Similar threads
