You know I can't help myself, so, here it is, focused and ready to go....
Soon in this theater..... Stay tuned!
Given the different language ... I couldn't see any of the lettering on the signs in the above night video unless it was right up close.
How does it go reading number plates at night? In this video there weren't any ... and that is the main purpose ... top priority.
Is VIOFO releasing a Cam with the 1.2 lens or have you custom fitted one?
I think in these midnight images, it is so dark that both lenses are using maximum exposure time, so there is the same amount of motion blur, the only difference is that the F1.2 lens can see deeper into the shadows and the slightly brighter areas are clearer because the darkest areas always lack detail.Given the different language ... I couldn't see any of the lettering on the signs in the above night video unless it was right up close.
In brighter conditions, once the camera gets away from maximum exposure time, there will always be less motion blur with the F1.2 lens, however in daylight F1.2 lenses normally struggle with sharpness and focus, which is why Viofo doesn't use one as standard. It will be interesting to see the daylight results...
"they struggle with a very short depth of field" = focus issues when used in a fixed focus camera that is exposed to a huge temperature range.F1.2 lenses don't "struggle with sharpness and focus". These fast M12 all use aspheric elements and they tend to be be well designed and have good resolving power. The real issue with M12 "Starlight" lenses is that they struggle with a very short depth of field which can make the optimal hyperfocal distance a challenge to determine and are often a compromise when used in dash cams. These are CCTV lenses designed to be used on static fixed mount cameras viewing static scenes rather than the dynamic, ever changing environment dash cams operate in where both camera and subject are moving while trying to capture subjects at various distances from the camera.
Having an aspheric element doesn't automatically make the lens perfect! There are still good ones and bad ones.
@dirkzelf, did swapping lenses in the Viofo require a complete tear-down of the camera and lens module?
Yes, I looked up how to on the good old Utube, the only thing is to fix the lens at focus. I use a lens fixing ring, but it's a little tricky since the whole construction of the lens Swivel mount doesn't allow easy access to the barrel and fixing ring. But be patiënt. You will figure it out.
Thanks! Did you use the AV out port into a monitor or HDTV to focus? The reason I'm asking about this is that I came into possession of a Viofo A119 some time ago and when I finally got around to checking it out, the focus was slightly off. I see that there is a good tutorial on this on YouTube. One of my main concerns was dealing with the lens housing ratchet spring, but it looks pretty easy. One time I opened up an old camera with a similar design and the spring shot off somewhere never to be seen again.
Hehe yeah this time of the year at night its easy to see where north are, if you have a clear view of the horizon.
Just pisses me off we now have a nation wide ban on any form of fire and grilling, i was planning for a nice chillout ( grill ) and scale offroading trip to the forest.
Then again at night there are not many other people in the forest, maybe a law or 2 will get circumvented though it is a 5000 Dkkr fine, they will have to find us first.
Viofo A119S - parking mode doesn't work | A119S | 1 | ||
R | VIOFO A119S let me down. | A119S | 3 | |
M | VIOFO A119S - screen | A119S | 11 | |
New VIOFO A119S arrived. First glance screenshots | A119S | 25 | ||
VIOFO A119S Screen Broken? - No video signal | A119S | 10 |
