Is it possible that the beeps are the cause, rather than the symptom? I know that sounds strange!
I have been looking at two different microSD cards that I used in the A129 this week. The only time I saw truncated files is when I had "All Sounds" enabled on the camera, and I've only done this recently for testing the g-sensor in parking mode. When I had selected "Button only" the files all appear to be fine, which is how I normally use the camera.
Perhaps this is just a coincidence as I cannot conceive how a logical link would exist between the beep setting and truncated files. I would need to do more extensive testing to verify any possible link, which I don't have time for at the moment.
I am using a beta FW for parking mode, not the current V1.9.
TonyM-
As you know, this problem of single and/or double beeps has been reported a long time ago on several threads here - almost as long as Viofo has known about the g-sensor sensitivity problem in parking mode! - - Presumably Viofo knows "something" about this issue, but as is the norm with them, they are keeping their lips sealed!!! - - After all, the A129 and A129 customers are not their priority...
Would it be hard for someone from Viofo to post on their own "Company User Forum" that they know this is an issue and it is being addressed? Not really. Will it happen? Probably not!
I personally solved this problem by switching from my Lexar 128 gb sd card to a Samsung Evo Plus 128 gb sd card purchased directly from Samsung. I didn't want to take any chance of getting a "fake card" on Amazon. Since I switched cards, the beeps have gone away.
Incidentally, I have always used the "all beeps" setting as I want to know if the dash cam is not recording for some reason (forgot to put sd card back in, etc.); if the setting is on "buttons only" you will not be notified that your dash cam is not recording. Hopefully that doesn't happen when you need some important footage.
I will put my old Lexar card back in my A129 in a bit to see if the beeps return. - - One would think that they would as that is the only change I made to my dash cam.
Btw, here are two other threads on this forum that deal with the beeps problem. The first link is only about 2 months old and the 2nd link goes all the way back to March, when I believe Firmware 1.5 was being used, ? mabe something even older!!!
My A129 is setup to record in I think 5 min lengths. I had an encounter with a crazy bicycle guy over the weekend and wanted to check out the footage. I've noticed, that I'm losing about 20 seconds between the recordings, and in this case I missed a crucial part where the guy hit a car on...
dashcamtalk.com
This is the first time I've encountered this and I hope there's an explanation to it (not an issue). So basically I was driving earlier and the front camera just gives me an short audible notification beep which I don't know what it was for. At first I though it was the G-sensor activating...
dashcamtalk.com
