Viofo A129 can't get into menu
Sdeel7491
Hi just got my self a Viofo A129 duo and started getting to know how it works!
Thought I was doing ok got into menu and worked through settings and formatted the card! Then came out of the menu and turned camera off
Just started it again pressed the record button to stop and get flashing red and I press menu button but nothing happens!apart from turning off.
Any suggestions would be appreciated cheers
mattguy10
While not recording, turn WiFi off on the cam by holding down the button all the way to the right and then try accessing the menu again. Only have WiFi turned on when you need it and don’t have it on while driving with the dash cam as it will lower image quality.
S
Sdeel7491
Cheers mattyguy10 works a treat were up and running again!!
