HonestReview
- Feb 9, 2019
- Sweden
So I decided after my performing testing on the A129 Duo's station mode, I would now flash back to the tried and true Version 1.5. I was running Firmware Version 2.1 for my tests. While using Firmware Version 2.1, I noticed odd behavior, and went ahead today to check my connections today. Making sure there wasn't some sort of loose wire on ACC. All A-OK on my camera.
Version 1.5: Turn off Car - Camera Immediately Enters low Bitrate Parking Mode. No Delay.
Version 2.1 - Turn Off Car - Camera records at normal recording, before entering parking mode several minutes later (Approximately 3 Minutes). Presumably by the GPS idle Feature??? And not through the ACC wire triggering parking mode.
This issue was replicated every time I turned off the car. Identical each time.
Flashing back to Version 1.5 just now, I verified the camera properly enters parking mode immediately after the car is turned off. Not true on Version 2.1.
I went through settings, timer was set to "On" (only other choices were minutes), Motion Detection was Off, and Parking was set to Low Bitrate on 2.1. So at a loss other than this being a bug.
