It seems you don't understand how the Neo is hardwired to the car,it is connected to the fusebox(2 wires + and -),and the + cable must be connected to ACC not to permanent + BATT.The camera is connected to Neo output via a Viofo 3wires HK to correctly and instantly switch to parking mode when I stop the engine and the Neo doesn't receive a live 14V input anymore(when this happens the Neo switch the camera to parking mode via the 3 wires hardware kit and feed the camera with 13V from its internal batteries)..So I need a 20A fuse which is live only when the engine is on for: 1.NEO to charge,and not draw curent from the car battery when the engine is off..Also this fuse is needed to be dead when I stop the engine,for: 2.NEO switches the camera to parking mode via the 3 wires kit,it does that when is not receiving any current on the + input from the fuse box...The 2 input(charge) thick cables of the Neo must be connected to ground and to some 20A (ACC ONLY) fuse in the fusebox.It is ok with my 10A fuse too because I let the switch on 5A charge mode on the Neo..I think I make myself clear now.Everything is working perfectly fine and the Neo is charged 100% every morning when I reach my office garage where the cameras will record for 9h in parking mode.The car battery is always between 95-100% charged(I have a bluetooth monitoring tool connected permanently to the car battery with a app on my phone).I'm only worried because this 10A fuse is dedicated for some safety systems of my car.I don't like the fact there is only one ACC switched fuse in the fusebox,this is the point of start of our discussion
"Simply plugging in a battery pack (Neo) without having a cutoff, will make the neo charge indefinitely until the battery is dead."
You can't put a 3 wires HK before the Neo because this 3 wires kit is designed for the camera only with a mini usb plug,even if you cut off the plug and manually connect the cables from the NEO input to the fusebox,those cables are too thin for the purpose,the Neo is drawing 70W(5A) or 120W(9A) when is charging(and only have two cables on the input side anyway).Also the little powercut box of that HK is designed for the camera 3-5W draw not for 70W-120W power draw.
