VIOFO A129 Modified Firmware MODs Archive
DarthMaul
Brno
Czech Republic
DCTeam, VIOFO A129 Duo
Interesting. What's the benefit of IR over a regular camera?
Rear camera doesn't benefit from the headlights light, so IR would be useful.
Sent from my SM-G935F using Tapatalk
TonyM
you can capture mice easier, also aim camera inside for interior Parking Mode Protection in total darkness.
Mousecam?
I'll wait for your separate IR thread to read more about this development.
BCHobbyist
BCHobbyist
Vancouver
A129Duo-7Ur A119Pro, A119S-6Vk A119, GitUp G3+F1, DCTeam
Harris48
Virginia Beach
Viofo A129
I see in the test footage videos WDR is set to off. Is it recommended not to use WDR? I'm currently running A129 MOD-2Uj.
Thanks,
Jamie
BCHobbyist
BCHobbyist
Vancouver
Thanks,
Jamie
Everyone should enable WDR for a week of more to notice any useful difference. You may discover as I did there is very little to gain, but under some lighting conditions it helps improve dark shadows.
R1KSU
Thornton, Cleveleys. UK
Zerogogo R2. Zerogogo RW100. Mini0906. Viofo A129
I have the 3hwk and the mod firmware and parking mode refuses to work on low bitrate or time lapse, my 64gb card has filled up from 9.30 this morning with 507mb files, before the mode firmware I was getting front 190mb and rear 160mb files.
I read a few pages back that Viofo have found a fault on parking mode? why are my files so big?
TonyM
The modified firmware runs both front & back cameras at higher bitrate than the standard Viofo firmware, so the file sizes will increase accordingly.
TonyM
I've had too many parking mode issues with V1.50 and modified FW derived from V1.50. I'm going to roll back to MOD-4Uf which was the last Mod based on V1.42. Then I can use the low-bitrate parking mode again.
Mtz
Nice place
Romania
Viofo A119. WR1. SGGCX2. GitUp.
The IR cameras are made to be mounted on the windshield and to record inside car, never outside car. The idea is to use it in Taxi, Uber, or for people which want to record what is happening in the car, usually recording from the front of the car to the back of the car.
enjoy,
Mtz
TonyM
enjoy,
Mtz
Thanks for clarifying the purpose of the new camera unit. Did I read correctly that the IR camera comes with a much shorter remote camera cable?
Mtz
Nice place
Romania
I expect it to be around 50-55cm.
enjoy,
Mtz
R1KSU
But that's a massive increase in file size!
Where can I get the v1. 42 firmware??
I currently have the brand new Zerogogo R2 dashcam that had front and rear facing cams in one unit, rear cam has 4 ir lights and is intended for passenger vehicles, it does seem to light up the interior of the car quite well.
TonyM
You're right - the file size increase should not have been that high from changing FW alone. Did you change the loop duration from 1 minute to 3 minutes?
R1KSU
I always have it at 3 mins, was 190mb, now 507mb! I swapped back to standard firmware v1. 5, but would like v1. 42 where parking mode works, lol
TonyM
507MB is about right for 3min at 24Mbps front camera high bitrate
190MB works out at about 8Mbps, which would have been low-bitrate parking mode
I went back to MOD-4Uf today which is based on v1.42 where the parking mode works, but also has the modified IQ which I like.
Similar threads
