VIOFO A129 Modified Firmware MODs Archive
BCHobbyist
BCHobbyist
Vancouver
A129Duo-7Ur A119Pro, A119S-6Vk A119, GitUp G3+F1, DCTeam
507MB is about right for 3min at 24Mbps front camera high bitrate
190MB works out at about 8Mbps, which would have been low-bitrate parking mode
I went back to MOD-4Uf today which is based on v1.42 where the parking mode works, but also has the modified IQ which I like.
The newer FW 1.50 added many features and I haven't located what broke Parking Mode when using our higher bit rate modifications. Beta testing one possible FIX now, waiting on results.
Your solution to downgrade MODs to access Parking Mode is easiest. Anyone using higher bitrates should change Looping from 3min to 2mins or even 1min to reduce the MP4 file sizes for less chance of corruption.
carguy4471
Can anyone advise what the updated parking mode is on this firmware??
Thanks!!
BCHobbyist
BCHobbyist
Vancouver
Thanks!!
VIOFO continues is adjustment both the 3-wire Hardwire Kit and Firmware control for auto Parking Mode on, ignition on/off, idle, standby sensing values. These all only work when connecting 3-wire kit to A129 side port not GPS module port. Improvements target stability and reliability while Parking Mode is enabled, currently set to 5 min delay to prevent trigger at long stop lights/traffic jams.
Power Bank users are restricted to Parking Mode Low Bitrate option, hopefully this will be expanded.
t4ckevint
I just got my A129 and have it running stock 1.50. Should I hold off on putting MOD-2Uj on my dashcam?
BCHobbyist
BCHobbyist
Vancouver
There isn't anything wrong with stock FW1.50 everyone should run it. Always good idea to understand the update procedure perfectly before diving into MODs. After a few weeks try any of my modified firmware and compare your own RAW footage.
TonyM
Is probably a good idea to stick with V1.50 for a short while to get used to the camera and review the video to look at the image quality. Then you can try one or more of the MOD firmwares and see if they are better for you.
Not all of the A129 have identical image sharpness due to tolerances in lenses and in pre-set focus position. Therefore high sharpening settings can look better on one camera than another.
DarthMaul
Brno
Czech Republic
DCTeam, VIOFO A129 Duo
True! In my case, the image on stock firmware is a bit too sharp, so I prefer using one of these MODs. I am currently still on 4Uj. As I noticed my rear camera is quite noisy compared to front on pretty similar lighting conditions, I am switching to 2Uj (equal bitrate on both cams) and see how it goes.
BCHobbyist
BCHobbyist
Vancouver
Created new A129Duo - STABLE versions 6Uk , 4Uk , 2Uk , See post #1 of this thread for details and ChangeLog.
These MODs are based on newest official VIOFO FW v1.50 , reduced Sharpness for those with 140 FOV Lens preferring slightly softer image quality. This will become Med/Normal level once Sharpness option is added to Menu.
Special thanks to @Bexx for Beta testing.
Higher Bitrate MODs improve image detail and increase MP4 video clip size.
Suggest using high Bitrate with outdoor temperatures as follows:
28-29Mbps Bitrate up to 20C/69F . . . . . . 20-25Mbps Bitrate up to 35C/96F
26-27Mbps Bitrate up to 30C/83F . . . . . . 10-19Mbps Bitrate up to 40C/102F
FWA129_MOD-6Uk_v1.50+26F+18RMbs+Sharp120+Edge132+DCTeam.bin
Download 6Uk > https://drive.google.com/open?id=1w7EiUF1enAFDYNlvAVnLp2WGzTn2VVBV
FWA129_MOD-4Uk_v1.50+24F+20RMbs+Sharp120+Edge132+DCTeam.bin
Download 4Uk > https://drive.google.com/open?id=1WwzrbQiKAUPIV7RiUriSkqs5No5yv2w8
FWA129_MOD-2Uk_v1.50+22F+22RMbs+Sharp120+Edge132+DCTeam.bin
Download 2Uk > https://drive.google.com/open?id=1u5bs7a_g-u0uoCcM_RjpYj9ctCvwUrtP
44003
Viofo A129 Duo Dash Cam Review > https://viofo-a129-duo-dash-cam-review.blogspot.com
DCTeam - CEO/CEH/CDO/DRD/DSP/IQE/PDU/SFC/LLS
YouTube Channel: https://www.youtube.com/user/BCHobbyist
DarthMaul
Brno
Czech Republic
Created new A129Duo - STABLE versions 6Uk , 4Uk , See post #1 of this thread for details and ChangeLog.
Special thanks to @Bexx for Beta testing. If anyone wants Front & Rear Cam = 22Mb/s version let me know.
Thank you! In this case I'll jump directly to 6UK/4UK since I preferred the reduced sharpness MOD :)
I would also like to try the 22/22 Mbps version of this MOD!
Sparkyy
Expanding my Firmware Modifications to include A129, A119S, A119, & A119PRO Dash Cams to enhance and improve image quality and function. You are invited to Post your comments, questions, ideas & footage below.
This post will be updated with all future MOD releases to keep everyone up to date.
Current Stable MODs for Public --- Updated January 11, 2019
MOD-6Uk - - - January 11, 2019 > Download 6Uk > https://drive.google.com/open?id=1w7EiUF1enAFDYNlvAVnLp2WGzTn2VVBV
- based on new official FW v1.50
- override BitRate Menu to increase from 20/16/8/7Mbs to 26/18/8/7Mbs on 60fps + 30fps !!!!
- override BitRate for Single Camera Mode 60fps + 30fps now are 24Mbs Wifi on !!!!
- changed Sharpness from 128 to 120 to set Med/Normal level.
- increased Edge Detection from 128 to 132.
- replaced Mic-Off + Wifi-Off graphics to improve visibility.
MOD-4Uk - - - January 11, 2019 > Download 4Uk > https://drive.google.com/open?id=1WwzrbQiKAUPIV7RiUriSkqs5No5yv2w8
- override BitRate Menu to increase from 20/16/8/7Mbs to 24/20/8/7Mbs on 60fps + 30fps !!!!
- override BitRate for single Camera Mode 60fps + 30fps now are 24Mbs Wifi on !!!!
MOD-2Uk - - - January 11, 2019 > Download 2Uk > https://drive.google.com/open?id=1u5bs7a_g-u0uoCcM_RjpYj9ctCvwUrtP
- override BitRate Menu to increase from 20/16/8/7Mbs to 22/22/8/7Mbs on 60fps + 30fps !!!!
- override BitRate for single Camera Mode 60fps + 30fps now are 22Mbs Wifi on !!!!
MOD-2Uj - - - December 24, 2018 > Download 2Uj > https://drive.google.com/open?id=19PN1EeF8h88sOxyNwz7QzS8w57zDPIIQ
FWA129_MOD-2Uj_v1.50+22F+22RMbs+Sharp123+Edge132+DCTeam.bin
- changed Sharpness from 128 to 123 to set High/Strong level.
MOD-27W - - - December 22, 2018 > Download 27W > https://drive.google.com/open?id=1yeuGFqCUwF2MGPEhdxIJOy1zdXuIFXhP
FWA129_MOD-27W_v1.50+27F+17RMbs+Default-IQ+DCTeam.bin
- unlocked MAXIMUM Bitrate to 27.6Mbs = 28Mbs clips.
- override BitRate Menu to increase from 20/16/8/7Mbs to 27/17/8/7Mbs on 60fps + 30fps !!!!
- uses Default Image Quality (VIOFO values sharpness,edge,brightness,contrast,saturation)
MOD-7Uj - - - December 22, 2018 > Download 7Uj > https://drive.google.com/open?id=1XZcpw190wi2QRxzNS6hnLdw5DWtqqSOT
FWA129_MOD-7Uj_v1.50+27F+17RMbs+Sharp123+Edge132+DCTeam.bin
MOD-6Uj - - - December 21, 2018 > Download 6Uj > https://drive.google.com/open?id=1yWqAQ7qiJDLZTz_mZ9RKzx85E3-ylL3T
FWA129_MOD-6Uj_v1.50+26F+18RMbs+Sharp123+Edge132+DCTeam.bin
MOD-4Uj - - - December 9, 2018 > Download 4Uj > https://drive.google.com/open?id=1vaWw127YmcPzLU7VJBLwqeD77TxfOUQn
FWA129_MOD-4Uj_v1.50+24F+20RMbs+Sharp123+Edge132+DCTeam.bin
Current Beta MODs for Testing --- Updated September 30, 2018
How to load Modified Firmware:
1) DOWNLOAD the version and modification desired.
2) COPY new FW MOD file to root of microSD card using computer.
3) RENAME the FW file from FWA129_MOD-4Uj_v1.50+24F+20RMbs+Sharp123+Edge132+DCTeam.bin ===> to ===> FWA129.bin
4) Safely Remove memory card from computer.
5) Disconnect power to Dashcam, disconnect Rear camera.
6) Insert memory card with binary file into Dash Cam.
7) Connect power to Dashcam wait 60 seconds for update to restart the Dashcam.
8) Dashcam will restart on its own, do not disconnect power cable.
9) Stop recording, then enter MENU and select DEFAULT Setting then wait for Dash Cam to restart.
10) Configure MENU settings Resolution, Loop, Sharpness, GPS, Date, Time Zone.
NOTE:
Computers show or hide file extensions, if you see the .bin after download make sure it stays after renaming.
If you don't see .bin file extension no need to add it since its there but hidden from view.
A129 is almost unbrickable if you don't flash the BootLoader. If update fails or is corrupted the BootLoader is still functional.
To restore Dashcam, copy official A129 firmware file to microSD card then Power-On wait 1 minute.
View the ReadMe and ChangeLog for details from my online MOD Archives.
Beta Testing Setup = CPL on if available, 1min clips, 1080P@30fps, EV=0, WDR off, Camera Model Stamp on.
DOWNLOAD A129 DUO Modified Firmware > https://drive.google.com/open?id=19l3yGyvkrRZMiyRBJVw7oGCFUcNWheYa
Forum thread VIOFO A129 Modified Firmware MODs Archive > https://dashcamtalk.com/forum/threads/a129-modified-firmware-mods-archive.35826/
Firmware Modification Guide for VIOFO Dashcams > https://dashcamtalk.com/forum/threads/novatek-nt96660-firmware-modification-guide-for-viofo-a119s-dvr.35502/
Troubleshooting Guide for VIOFO A119S or A119 > https://dashcamtalk.com/forum/threads/troubleshooting-guide-for-viofo-a119s-or-a119-dash-cams.35375/
Disclaimer: All BCHobbyist Modified Firmware is rigorously tested by DCTEAM Members under all conditions world wide. These MODs are not official VIOFO releases and considered Beta Firmware, I/we are not responsible for damage, loss, injury, or greatly improved image quality, use at your own risk.
BCHobbyist will build your Custom A129Duo, A119Pro, A119S & A119 Modified Firmware making adjustments to:
Bit Rate / Frame Rate / Sharpness / Edge Detection / Color Tone / Hue / Brightness / Saturation / Audio Quality /
Menu Text + icons / MP4 embedded Text / Startup Logo /
DashCamTEAM is a group of dedicated, respectful and helpful Dash Cam owners.
We are not associated with DashCamTalk or any Vendor or Manufacturer.
Our Forum Profile identifies active Members.
Please report all issues, thank you for using DCTEAM MODS.
Send MOD Requests by clicking my DashCamTalk Avatar to start Private Conversation, Contact me on BCHobbyist YouTube Channel.
great work on the firmware, going to try one, will all the versions of firmware work on the A129? also i have 2 of these cams, 1 in each car, they have different lenses in each pair of cams, will these firmware's work in both lens versions of the A129?
BCHobbyist
BCHobbyist
Vancouver
All A129 modified firmware works with any Lens, but image quality varies depending how Lens was focused on production line and that is inconsistent, thus the reason for different MODs. Try them and find the best for your Lens, always compare against latest official firmware version. The Uk series seems to provide better sharpness for wider angle 140 FOV Lens, use Uj series for narrower 130 FOV Lens.
BCHobbyist
BCHobbyist
Vancouver
My A129 verses A119 side by side comparison was delayed but turned out well. The image quality when viewed at 1080HD setting is acceptable and reveals some interesting results, was actually surprised at how well A129 at 1080P did against A119 at 1440P. In my opinion the A119 Dash Cam has better image clarity and focus but dark at night. The A129 is very close at 1080P and includes dual camera support, dual channel WiFi, improved stable mount, newer Novatek NT96663 chipset, Sony 2MP IMX291 Exmor R Starvis Night Vision Sensor, Bluetooth Remote and 7 Parking Mode options, making the A129 a better value.
BCHobbyist
BCHobbyist
Vancouver
Mike-DH
Germany
How can i check which Lens my A129 has? Or is this not possible?
TonyM
From post #193
Lens 1 = 130 FOV + metal base + supports original CPL Filter + coated reduces some reflection and slightly changes color tone and slightly darkens image. (approx 125-135 Diagonal FOV)
Lens 2 = 140 FOV + metal base + wide angle + requires larger beveled CPL Filter to prevent vignetting + uncoated brighter image. Many owners prefer the original wide angle brighter uncoated F1.6 Lens 2.
Combi
Bloomington, Indiana
Viofo A129 Front
Newbie here. After I install a new modded firmware Do I have to set the cam to 1080@30 fps or the highest resolution and 60 fps?
Wdr off and ev 0?
Thanks in advance.
Fostel
Viofo A119 >> A129 Duo
Thanks for sharing. I just learned that they were selling with two different lenses. Which one is currently used by them or they are fixed randomly at the same time?
I've just checked mine that I purchased from VIOFO UK Amazon in December 2018 and I think it is LENS1 (the inner ring is there). Should I be happy or opt for a LENS2?
As a photographer, I would say that coated means better as fewer flares and reflections but still, I rather choose 140˚ than 130˚ for a dashcam.
TonyM
Wdr off and ev 0?
Thanks in advance.
Welcome to DCT.
From Post#1 of this thread:
The default setting is 1080p60 single channel, or 1080p30 if recording dual channel. I see you have listed A129 Front as your camera, so I would recommend 1080p60 for you. WDR is off and EV is 0 by default. The only things you need to adjust are things like GPS on/off, time zone etc. Later you can adjust EV, loop duration, parking mode options etc to suit your preferences.
Combi
Viofo A129 Front
Welcome to DCT.
Thank you, This morning before going to work I updated the firmware to the MOD-7Uj and yes, noticed that those were the settings. Will see in the afternoon how the quality compares to the Original V1.5. Im coming from Roav S1 DashCam, returned it due to the crappy echoing audio.
BCHobbyist
BCHobbyist
Vancouver
Wdr off and ev 0?
Thanks in advance.
I always recommend lower Bitrate modified firmware to new Dash Cam owners. Everything you need to know is found in Post #1 of this and all my MOD threads.
Always use 1080P at 30fps to start it actually provides better night image quality than 60fps, For high Bitrate MODs always set Loop Recording to 2mins as showing my videos to reduce the larger MP4 file sizes, set WDR off and always leave Exposure 0, never use LDWS or FCWS they are gimmicks.
Thanks for using my MODs.
Remember to remove the plastic Lens protective film and then clean off the horrible cloudy residue left on the glass (repeat on both sides of CPL Filter), use Lens cloth or watch my Lens cleaning video on my BCHobbyist YouTube channel.
Similar threads
