- Jan 27, 2013
- Australia
- Too many ¯\_(ツ)_/¯
worth trying again
my system security prevents me from accessing your questionable file serverYa that'll be tomorrow's project. Just trying to get the damn video to work with audio. So BChobbyist can see what I'm seeing.
I didn't view the video, I don't see the point of watching a video to show what you've already describedJokin was able to see video file. I sent him it, tool
where is power cable attached? to mount or side of camera?Jokin was able to see video file. I sent him it, tool
I have a 2015.5 Volvo S60. Hardwired to Fuses 14 = Front Passenger Seat (Power) for Battery and Fuse 22 (12 Socket Tunnel Console) for ACC.
Fuse Box Image
Fuse Diagram
Fuse Descriptions
Sigh well video shows 0 seconds to 26 car running on engine and camera running off normal power. 26 seconds I shut down car it switches to park mode. I then shut off camera and at 58 seconds hit key fob to lock doors. Camera turns itself back on.
suggest loading Official FW1.50 for 2 weeks and see if anything odd happens. At least that way you can confirm all wiring works perfectly. I'll recode the MOD but don't have a Hardwire Kit to test on.Power is attached direct to Camera (Not GPS). Battery = Fuse 14 Front Passenger Seat. ACC = 22 12v Tunnel Console. Black = Grounded to metal screw with metal washer.
I'd put my money on a bug in the modded firmware.... I'll flash back today to stock and "verify" it isn't my car.. Even though I regularly shut off camera and locked doors before Mod and never had issue... I'll "Double Check".
At least thats what it should do, you'd have to disable Parking Mode to prevent it from turning on. Sounds normal to me.
This is how I currently use my camera with the 3-wire kit. I manually turn off camera when I park in my garage. I use Low Bitrate parking mode. No problems.That is incorrect. On stock firmware, I was able to power off the camera manually without having to disable parking mode. So once car was shut off and camera went into parking mode, I could hold down power button and turn camera off. So it wouldn't run while sitting in the garage. Doing so under stock firmware never required disabling parking mode.
Now, I can turn off parking mode each and ever time I want to disable camera. I guess that is a "work around". But it appears to be more of a bug in the hacked firmware since the hacked firmware behaves differently than the stock one.
In my attempts to narrow the gap between 1080P and 1440P this is the closest so far. Turned out better than expected with video comparison posted this weekend.
Your issue sounds like your ACC fuse is becoming energized when you press the door lock on your key fob, thus restarting the camera. What fuse are you using for the yellow ACC wire?
Ok so Im going to have to do some testing and find out what's going on.
Stock Firmware is behaving same way. Exit Car, lock doors, camera turns on. Only way to get it to shut off is turn off park mode.
My car has been sitting a few days and battery is "low'. I have 12.4 volts in my battery (75%) due to 5 years of age. Cutoff is 12.2 (50%). Im going to drive my car around a bit in hour or 2 and then see what happens when battery is charged.
So you can disregard all I've said. This appears to be an issue on my end somewhere. Maybe I'm just noticing it turning back on after locking and hadn't paid attention before or Maybe this is a new issue due to low battery warning. I'll report back after I've done more testing.
I do this daily and the camera has never turned back on.Do me a favor please. Put Camera in Park Mode. Shut off car and shut off camera before entering park mode. Lock your doors if you have power locks. Repeat process after camera enters park mode. Lock doors.
Does camera turn itself back on?
Please go back and delete all Firmware bashing posts you made with no facts or evidence, thanks.Ok so Im going to have to do some testing and find out what's going on.
J | Viofo A129 Duo Parking Mode Problem - Please Help | A129 / 129 Duo | 11 | |
W | Saumsung MicroSD + Viofo A129 Duo | A129 / 129 Duo | 4 | |
Y | Installing VIOFO A129 DUO in 2018 Nissan Murano | A129 / 129 Duo | 4 | |
M | Viofo A129 Duo questions | A129 / 129 Duo | 4 | |
D | Viofo A129 Duo parking mode is bad | A129 / 129 Duo | 18 |
