Have you checked the card on a PC to confirm the files are actually not there?
Ask them for the pin outs and cable type then you can make your own length. 😉Just an update to this thread regarding issues I have encountered with my A129 Plus Duo. I changed cars and was unable to recover the cable to the rear camera. After going through 2 new cables, it seems that not all cables are alike. The cable was marked Viofo A129 but does not work for the A129 Plus. Found this in the Viofo website:
"Please note A129 Plus Rear Cable is unique and can not be used in A129 DUO/PRO dashcam".
https://viofo.com/content/37-viofo-a129-plus-duo-dash-cam-support/#FAQs
(see - Can I Extend my rear cable?)
Yes, the rear cable for A129Duo/Pro cannot be used with the A129Plus. The longest rear cable for A129Plus we have in stock is 10M.Just an update to this thread regarding issues I have encountered with my A129 Plus Duo. I changed cars and was unable to recover the cable to the rear camera. After going through 2 new cables, it seems that not all cables are alike. The cable was marked Viofo A129 but does not work for the A129 Plus. Found this in the Viofo website:
Not a length issue, the pins are wired different. And, Viofo AU are out of stock.Ask them for the pin outs and cable type then you can make your own length. 😉
How bout it @VIOFO-Support
Yeah i understood that.Not a length issue, the pins are wired different. And, Viofo AU are out of stock.
Good day to you , a229+ installed and man rear camera is no way equal quality as front anyway what exposure rear camera setting you recommend considering I am in newfoundland Canada with 90% dark and cloudy environmentYes, the rear cable for A129Duo/Pro cannot be used with the A129Plus. The longest rear cable for A129Plus we have in stock is 10M.
