Maybe you make the mistake of thinking that those vents are functional vents and not just decoration on what would otherwise be a rather boring looking piece of visible plastic. Opening them up may even have a negative effect on the carefully designed and tested air flow within the camera and definitely destroys your warrantee!
Note that there is also a vent at the front bottom (assuming lens is at the front), which on mine does appear functional, presumably cool air is supposed to go in that one and over the components behind it, rather than in the one you have uncovered, uncovering the bottom rear vent may result in the cool air not passing over certain important components. Also note that there is no vent at the top where you might expect one to let the hot air out - the cooling system on this camera is not quite as simple as people might expect. Also moving the antenna may affect operation, maybe the vent was allowing the radio waves out and the antenna is now behind RF shielding? Plain plastic isn't always simple plain plastic! Or maybe since you have now moved the antenna relative to the sensor which it is very close to, you will now get RF interference on the image.
Since it was already working 100%, there will be no way of knowing if you have improved the cooling or had no effect, and if it now dies then we will have to assume that your changes had a negative result!
I think it is a mistake to think that the piece of tape you have removed was not functional in some way, clearly it was not there just for sticking the antenna to.
