As i recall the hardware are much the same ( SOC / sensors IMX 291 )
SG probably use other lenses and other "little" things
Viofo as i recall have a optional BT event button, i don't think SG have this option.
SG don't mention wifi type, viofo say 2.4 & 5 GHZ
SG you get the dashcam viewer software for PC & MAC too ( i think that cost 20 USD if you buy the player yourself on the side, both brands are supported by it as i recall )
Viofo have GPS antenna in mount, SG have GPS antenna on a wire.
SG come with CPL filter for front, i don't think the A129duo do so that's a additional buy too.
SG give you 2 year warranty ( register ) viofo i don't know maybe just 1 year.
Ease of use = same
Heat tolerance also much the same SG maybe a little bit better
Capabilities = much the same.
Least issues = same i think but if you have any SG are probably the better company to deal with.
Tech = much the same.
Dont install and forget any camera, you be wise to spend 10 minutes or so on the computer every month or two looking over the recordings on the memory card.
