TonyM
- Jul 30, 2013
- United Kingdom
- A139, M1S
Viofo A139 - First Impressions
My first impressions after using the A139 3CH dashcam for a week :
The main unit with front camera is well made. It feels robust and secure on the GPS mount. The lens rotates up and down smoothly to any angle, unlike the clicked positions of earlier wedge cameras from Viofo.
In my car the A139 fits nicely on the black dots behind the rear view mirror, up against the right side of the sensor housing. Note that the camera slides off the GPS mount by sliding away to the right. The microSD card slot is also on the right side, above the lens barrel. The A139 may be more difficult to install on the left side of the screen if that is where you normally place your dashcam.
The coax cables that run to the interior and rear cameras are thin and easy to install behind headliner and door trim, however I find the brass plugs stand out against the black camera and cables. The end connectors are a push fit that clicks into place - this feels OK, but I would not want to unplug and re-plug the cables frequently. Therefore this may not be the best choice for someone who removes their camera from the screen each day.
The interior and rear cameras rotate smoothly up and down - in fact they can rotate a full 360 degrees. The A139 rear camera (left) is a similar shape and size as the remote camera on the SG9663DR (right).
Note the difference between the cables. The thin coaxial cable of the A139 is more discreet and does not rotate with the camera, although the captive mini USB plug on the SG9663DR feels more secure.
The latest FW V1.0 1113 allows the rear camera to be flipped with the mount on the other side.
I will add further observations in the next few days, after testing more functions and video settings.
