Think I may know why this rebooting issue occurs. I was testing an A139 3-Ch and connected the power cable to the main camera. The main camera never has an issue.
Then I connected the coaxial cable of the Interior Cam into the main camera. The reboot issue started again. Oh no. Unplugged power cable. Reconnected power cable and Interior Cam cable but this time I held everything (the cables) with my hands. After waiting a bit, the A139 said, 2 channels recording. I then connected the Rear Cam cable in the main cam. Held all 3 cables tight with my fingers. 3 channels recording.
So, the constant rebooting issue of the A139 3-Ch is more than likely due to the coaxial cable connection to the main cam. I never picked up on this before because the cables were in tight, click, but if for some reason the main cam isn't detecting the coaxial cables (if a cable is plugged in. if no cable is plugged in, it doesn't affect the cam as it will just ignore that coaxial input) from either the Rear or Interior cam, then it keeps rebooting. The cable has to be solidly in place in the main cam so the cam detects the connection is solid.
(when this rebooting issue happened on my original A139 3-Ch, even making sure the cables are in tight didn't seem to resolve the problem but that may have been due to the heat having already killed some of the electronics or the electronics associated with the cam input port so it no longer mattered what the connection is like). There obviously is wiring or a chip that detects if a coaxial cable is connected to the input ports.)
The condition of the coaxial cable connector may play a part in this solid connection. When I first purchased the original A139 3-Ch, I would plug and unplug the cables often without any issue. I would plug and unplug the Rear cam at night and use the Interior cam instead in Parking Mode. Over time, the coaxial cable connector could get dirt on it or a thin film may be on it or just wear and tear. I am only presuming these things as I really have no idea. The tolerance on the connection (when the cam detects the cable it is solidly connected) must be very tight. I know this to be the case from personal experience where if a cable isn't tightly restrained in place and a slight bump happens while driving, it will affect the ability of the cam to detect that coaxial cable input correctly. But in these cases the cam doesn't constantly reboot. I might get a tic tic, tic tic, tic tic, tic. Until I secure the cable so it isn't affected by any movement. So, not totally sure what causse the cam to constantly reboot. I just happened to find one instance that causes it.
In the above situation, I can't recall if the cam would reboot or just go beep beep, beep beep. I have a post in one of the threads on this issue. I will have to go and raed it to remember what the cam did in the scenario.
If you allow the A139 to keep rebooting, it may eventually heat up. It is possible other factors may be in play. But in my case, the constant rebooting can lead to over heating to where the cam is too hot to touch.
If you allow the cam to keep rebooting, it will eventually heat up. This may then kill internal electronics. So, this all comes back to the issue of how finicky the coxaial cable connector is to the main cam. The cam is not smart enough to stop rebooting if it doesn't detect a prefect connection. I'm trying to remember if this rebooting happened when my original A139 was new and the coaxial cable connectors were new. Who knows if the coaxial cable conector needs to be cleaned after some time, using something like isopropol alcohol (dirt, pollution from inside car can eventually coat the metal parts of coaxial connector).
