Müller
Hello.
I scratched my head regarding the following, but cannot tell if there´s actually any merits to it:
1.) Place a router with a simcard nearby the A139 (or several A139s) in station-mode. Connect the A139 to the router. Transmit the live-stream(s) over cellular-network and watch it/record it/store it (them) anywhere (?).
2.) To even get around ANY antennas and thus ANY hf-struggles: Assumed an A139 is modified like this, then there is a hf-output on the cam which is waiting for a 50Ohm hf-device to be connected to, usually a 50Ohm-WLAN-/Wifi-antenna. This (sending) antenna would transmit to a second, receiving antenna, which is also a 50Ohm device that is plugged in the corresponding connector on, for example, a router.
So the electrical-/hf-connection basically/simply consists of: two hf-connectors, one on the cam and one on the router and a 50Ohm connection-line between them (the two antennas) AND a more or less high-loss air-gap between the antennas.
But, and this is where the expertise of actual hf-knowledgeable people might be required: Shouldn´t it be possible to eliminate both antennas and the high-loss air-gap between them (the modified A139 and the router) and replace that by a short 50Ohm hf-/coax-cable, connected on one side to the modified A139´s hf-output and on the other side directly to the hf-input of the router? That would basically be nothing else like transmitting via ideal, quasi lossless 50Ohm-antennas AND without an air-gap between them, means: the hf-circuit from cam to router is working with the correct 50Ohm resistance but with nearly no losses which would then, in whole, behave like an (yes, bulky) A139 with an "integrated" sim-module ...
