VIOFO A149 Pro Duo - Q&A
Chuck McCoy
California
2027 Min. Spec: STARVIS 3 & HDR & 1mA LPID & 4CH & FastBoot
Q: For customers upgrading from A129 Pro Duo, are any components compatible?
1.) GPS Mount
2.) Rear Camera
3.) Rear Camera Cable
4.) USB Power Cable & Car Charger
5.) HK3 Hardwire Cable
6.) CPL Filter
A:
No, A149 Pro Duo uses all-new upgraded components.
Q: Is A149 Pro’s all-new upgraded Processor / Chipset the same as T330 & T340?
A:
Q: What image sensors does A149 Pro Duo use?
A:
Front: Sony STARVIS 2 (IMX678) 4K
Rear: Sony STARVIS 2 (IMX662) 1080p
Q: What is FastBoot, how does its work, are there any downsides?
A:
Q: What CPL Filters are used?
A:
Front: CPL-800 (included)
Rear: CPL-600 (optional)
Q: What Rear Camera Cable does A149 Pro Duo use?
A: Proprietary Type-C to Type-C (not MCX Coax)
Q: Why does A149 Pro Duo use a new Hardwire Cable called HK6-A?
A:
Q: What is available recording time with 512GB VIOFO Brand SD Card Maximum Bitrate?
A:
Q: What is A149 Pro Duo Maximum Bitrate?
1CH
2CH Front
2CH Rear
A:
Q: Does A149 Pro Duo have 1mA LPID (Low Power Impact Detection)?
A: Yes
Q: What is power consumption difference between A149 Pro Duo vs. A329S in LPID (low power impact detection) Parking Mode?
A:
1mA = A149 Pro Duo
39mA = A329S
Q: Is A149 Pro’s 1mA LPID a big improvement over A329’s 39mA LPID in parking mode duration?
A:
BP60: 64Wh ÷ 0.4914 Watts = 130 Hours (A329S)
BP60: 64Wh ÷ 0.0126 Watts = 5,079 Hours (A149 Pro Duo)
If you know any answers please drop ‘em bellow, and I’ll update this post.
Q: What was Firmware Version delivered with camera on 10/1/26?
A: V1.0_260915
Q: What was OTA Firmware Version when connected to APP, and prompted to update?
A: V1.0_260923
In my timed power on tests with a pre-release firmware which had the Fast Boot feature something you could enable/disable, from power off to first video frame was 3.03 seconds [front] and 3.01 seconds [rear]. The setting to enable/disable the Fast Boot feature was removed in the production firmware making the Fast Boot feature enabled all of the time. I'll have to rerun the power up tests to check both the [cold start] VCC off/ACC off and [warm start] VCC on/ACC off to see how long each of those power up situations take to start recording. Now that the A149 Pro camera is installed in the car, I'll have to remove the rear camera from the rear window to run those tests.
Q: How long does it take A149 Pro Duo to start recording from completely powered off state, (cold start)?
I have a feeling I’ll need to re-test after we get 1st OFFICIAL / PUBLIC FIRMWARE on VIOFO website.
We got an OTA Firmware update two days ago.
V1.1_261021 OTA Change Log:
1.) Optimized IQ, and other bugs fixed.
Bootup time has been reduced from 5.14 Seconds down to 1.99 Seconds.
I’ll need to confirm on the bench with identical power supply & configuration.
