VIOFO A229 DUO FIRMWARE
Hi,
I downloaded latest firmware to A229 Duo and put it to root of the micro-sd card. Then I inserted card back to camera and powered on. Red light blinked rapidly for a while. Then camera said, card error, format the card. I did that on my pc (exfat, default allocation size). Card is Sandisk 128GB and it works perfecly if I copy files to or from it with my pc.
But camera does not power on any more. Only constant red light when in power cord. I tried hard reset button, but still only constant red light.
Is the camera permanently bricked, or is there any trick to try to recover it?
Repeat the update process, insert card with the firmware on root folder and power up the dashcam, see what you get. I wish you luck
Why didn't you format the memory card in the DVR when it suggested it to you?
From personal experience: The speed of the memory card does not affect the DVR firmware.
Take any memory card up to 32GB. Format it to FAT32. Download the firmware to this memory card.
Insert the memory card into the turned off DVR. Turn on the DVR.
If the firmware is not updated, please contact support.
A229 Duo did not actually even offer a chance to format the card although it suggested to do it. I did not find any 32GB card, but tried with another 128GB card. Dashcam stays in "red light only" mode. If I push hard reset pin on the hole, red light turns off but when I release the pin, it comes back, but camera does not turn on. I went to my car and tried if hardwire kit manages to turn it on, but no luck.
Attention , to update the firmware, according to the Viofo description, use a card of smaller size < 32 Gb ... Any type and manufacturer 🙂
Finally found 32GB card and using that for firmware update did the trick. Firmware is now updated and I could format 128GB card in the dash cam. A229 Duo works now - almost. Screen does not turn on. Backlight turns on, but picture itself does not. I think the screen is simply broken. Warranty time is over as I bought this once it was released back in 2022. I can use Wifi connection and Android app to change settings etc. I don't think firmware broke the screen. It was blank already before. I haven't noticed that in the car as camera is installed behind the rear mirror.
Firmware is VIOFO_A229_V1.2_20230920
Finally found 32GB card and using that for firmware update that did the trick. Firmware is now updated and I could format 128GB card in the dash cam. A229 Duo works now - almost. Screen does not turn on. Backlight turns on, but picture itself does not. I think the screen is simply broken. Warranty time is over as I bought this once it was released back in 2022. I can use Wifi connection and Android app to change settings etc. I don't think firmware broke the screen. It was blank already before. I haven't noticed that in the car as camera is installed behind the rear mirror.
Removing and reconnecting the ribbon cable for the LCD screen may help with the screen issue.
My A229 Duo has been on firmware V1.2_20230413 for nearly a year and the dashcam has performed flawlessly since I installed it in December of 2022. I usually update the firmware shortly after a new version is available, but I've been busy. The older firmware has been working just fine, even without formatting. I finally got around to updating to V1.2_20230920 today. Hope I don't regret it.
I am on V1.2_20230920 as well but have had a few weird issues. Twice it started in the sd-card mode. This is with the hk-4 hardwire. Restart fixed it both times. Once it lost all it's settings after I did a card format from the camera. Been fine lately so not replacing yet but my eye is on the pro in the future. Still happy with it for now.
A new version of the firmware is available for download on the Viofo website.
FWA229A_V1.2_20240929
Change Log:
1. Added: Match the BTR200 remote
2. Trivial Bug Fixes.
