Viofo A329 Review
Viofo A329 vs Viofo A139 Pro dash cam night time HDR footage
Will be nice if you will want to make the same night test by using the 1034 and 1119 firmware for A139 Pro.
Okay here is the comparison at night ov Viofo A129 Pro vs Viofo A329
A129 pro peripheral is good at seeing clouds and black dots. A329 is also good at reading license plates and surrounding text.
A129 pro wdr uses A329 hdr.
We will reach the ideal level when we have both good peripheral vision and read license plates.
Accordingly, what if WDR works at the top of the video and HDR works at the bottom (at plate level)? Maybe A129 pro can't do this, but can A329 handle it?
Has anybody compared the A329-rear-camera to the rear camera of the A229 Pro yet? I noticed a small improvement there as well.
But unfortunately not enough time to edit it for a comparision now since I have to sort out video material from 13 different dashcams first.
Will do a video about it in a few weeks.
I have a video that contains nighttime footage from the A329 rear, A229 Pro rear, Thinkware U3000 rear and BlackVue DR970X rear dash cameras.
I have a link to that video in this post:
There is no reason why you can't have both HDR and WDR on the full image, but the video isn't going to end up great quality when you squash that huge range of light levels into an 8 bit video file. I think you will have to wait for the 10 bit dashcams to arrive to properly see both very bright and very dark areas of the image in reasonable detail.
WDR only at the top of the image is not going to look good, the A129 Pro is not much good at illuminated signs.
I think the A129 Pro sensor actually has proper HDR, it would be interesting to see the result with an updated processor, probably not as good as the A329 at night, but the A129 Pro does have an excellent sensor for daylight.
5 camera box mentioned sounds good (with cloud please)
I don't believe the box solution is going to be viable long-term.
I've banged on about it a few times and so have others here, like why can security cameras operate so well under heat and stress but not dashcams. It looks like we are FINALLY starting to see better chipsets from Novatek in devices like the A329. Sure, the architecture is like 15 years old but it's a start.
This should alleviate a lot of the heating concerns especially now that a lot of manufacturers have got access to Starvis 2 sensors now, and we'll be recording at 4K multi channel whether we like it or not lol. Therefore there won't be a need for boxes (increased manufacturing cost to the dashcam makers).
Tunnel Tests Videos are coming this week with Viofo A229 Pro (Tuesday), Viofo A139 Pro (Wednesday) and Viofo A129 Pro (Thursday) all featuring against the new A329.
Even that single freeze-frame shows some of the improvements in the A329, and also some of its limitations in that challenging location.
Viofo A329 vs Viofo A229 pro Dash Cam Time Lapse Parking Mode
Nice video, have to wonder why @viofo is not advertising the 40% longer parking mode record time from the A329 2ch low bitrate parking mode and 68% longer parking mode record time in 2ch timelapse parking mode? Seems quite a significant improvement from the more powerful processor to me!
In your table you have Timelapse 1fps SNV "coming soon" for the A229 Pro. Have Viofo advised they are bringing this feature to the A229 Pro?
I like the brighter image in the A329 SNV, but the A229 Pro has noticeably less blur which could make a difference in some situations, perhaps for identifying someone who bounced a basketball on your windshield at night!
I received a sample firmware for the A229 Pro. Where i did test the current draw and it was low like A329. However i did not test whether the video quality was the same.
May I know if the A329 knows when to jump into low-bit rate parking mode when engine is off when hooked up to a battery pack?
your ignition gets turned off and battery pack then goes into parking mode.
