VIOFO A329 / Telephoto Camera / Video and Screenshots
Karagandinez
Deutschland
Germany
At the moment Viofo, Vueroid and Vantrue
Screenshots from the main camera A329_Night
FWA329_V1.0_241009
Resolution: 21:9 / 3840ั…1600
Bitrate = max
CPL = on
EV = -0,3
You can compare it with screenshots from the A229 Pro and from the additional camera with a telephoto lens here:
Screenshots_A329_Sun in the forehead
FWA329_V1.0_241009
Bitrate = max
CPL = on
EV = -0,3
Version: 3.2.19
Aktualisiert am 12.12.2024
1. Add Bluetooth Button Function for A129 Pro/A129 Duo/A129 Plus/A229 Duo.
2. Add Privacy Mode for A229 Pro/A229 Plus/A329/VS1.
3. Add Timelapse 1 fps (Night Vision), Stamp Text Color options for A229 Pro/A229 Plus.
4. Add Parking Mode option for Bluetooth for A229 Pro/A229 Plus.
5.Fix known bugs.
Version 4.2.6
5.Fix known bugs.
A little about the operation of the GPS modules in my A329 and A229 Pro...
A229 Pro 2CH was purchased at the end of August and was installed in another car.
At the beginning of winter, I installed A329 1CH and A229 Pro 2CH in the main car.
The models are on the windshield at the same level and about 25 cm from each other.
Since a lot has already been written here about detecting a GPS signal on these models,
I decided to check how the GPS modules behave on my models.
Both models have the latest available firmware. After viewing the memory cards from both models,
I found that the speed stamp after starting recording appears faster on the A229 Pro 2CH than on the A329 1CH.
This happens with every cold start.
Over several days of monitoring, the longest time from the start of recording until the speed stamp
appeared on the video was 60 seconds for the A229 Pro versus 70 seconds for the A329.
A229 Pro is connected via HK3-C.
A329 is connected via HK4.
Power to HK3-C and HK4 is disconnected during long-term parking / overnight near the house.
Since I have a VS1 installed on the rear window, I installed the rear camera from the A329 on the windshield, slightly to the right of the left pillar.
FWA329_V1.1_241227
Bitrate = max
EV = -0.3
CPL = on
Daytime screenshots from both cameras
Nighttime screenshots from both cameras
What was filmed on the latest firmware is in the car and will be next time. ๐Ÿ˜‰
Lols firmware came out on Saturday I updated mine right away so yeah a bit late then. Wait til next time for screenshots then
The rear camera of the Viofo A329 is installed on the windshield slightly to the right of the left pillar.
Firmware: V1.1_250120
Front video quality looks great! I'm having to replace a failing camera, and the A329 looks like it's gonna be the one for me. Thank you for sharing these samples.
I do hope VIOFO will lessen the extreme sharpening on the rear camera in a future update. It is way too over-sharpened and it looks almost like 1080p video to me because of how over-sharpened it is. Not terrible quality by any means, but it would definitely look so much better with less sharpening.
No more experimenting with installing a rear camera on the windshield instead of a telephoto.
Viofo made a telephoto camera that works with the A329 instead of a rear camera. ๐Ÿ‘
This telephoto camera also works with the A329S when connected to the rear camera jack.
I'm not getting the sharp number plates like in those night shots. I'll have to experiment with my settings
