Karagandinez
- Nov 27, 2020
- Deutschland
- Germany
- At the moment Viofo, Vueroid and Vantrue
I think Viofo dashcams have always done that!Update: I've been able to replicate this issue. If you remove the dashcam from the mount, it shuts off, and then you slide it back on while the car is still parked, it doesn't see the new parking mode options when you reinstall it and thus it defaults back to parking mode off. However, if I power the car on, then the new parking mode options show up.
Again, the issue is that the new parking modes can disappear while the old ones remain active. If your selected parking modes goes away, parking mode will get disabled altogether. This is different from previous Viofo’s.I think Viofo dashcams have always done that!
Allthough it might go back into parking mode after 5 minutes.
Isn't the issue that you removed the power, then replaced the power, but gave it no ACC signal. In that case, Viofo dashcams do not enter parking mode until they get an ACC signal, and then it is removed again. So maybe there is a problem when you remove the power, replace the power, and then go into the settings before you have given it an ACC signal, while if you had given it an ACC before entering the settings then there would have been no problem...Again, the issue is that the new parking modes can disappear while the old ones remain active. If your selected parking modes goes away, parking mode will get disabled altogether. This is different from previous Viofo’s.
Just went and played with it some more. You can enter the settings as soon as you put the dashcam back on the mount and before you start the car back up, but because it boots up in driving mode even though the dashcam should be in parking mode. My guess is it's unable to recognize the HK4 present when it starts back up with the car parked and so it disables hybrid parking mode at that time, even after you turn the car back on and the dashcam boots up normally.Isn't the issue that you removed the power, then replaced the power, but gave it no ACC signal. In that case, Viofo dashcams do not enter parking mode until they get an ACC signal, and then it is removed again. So maybe there is a problem when you remove the power, replace the power, and then go into the settings before you have given it an ACC signal, while if you had given it an ACC before entering the settings then there would have been no problem...
Given that removing a memory card while the dashcam is running can potentially lead to corruption issues, I always like to power down the dashcam before removing the memory card. It's also very common that after I'm done grabbing footage, I go back in the garage, reinsert the memory card, and plug in / remount the dashcam. (Some dashcams like Blackvue's require you to remove the power cable in order to access the memory card.)I can understand why it's doing that - when you disconnect the power and restart it, it's starting fresh with no engine running, so the Hybrid parking option is no longer possible.
The issue arises, like you say - when someone sets their camera up in that mode and leaves it thinking it's permanent and good to leave, won't realise that disconnecting the camera and reconnecting it some time when the engine is off will no longer make that option possible - but will then remain in that state until its manually changed again.
It would probably take a lot of work in the firmware to make it so that you can have a default settings for ON whenever the camera gets ignition power again, so it reverts back to that setting automatically, rather than having the user go back in to settings to change.
Is there any way for the dashcam to recognize the HK4/HK6 if it's plugged in and powered on while the vehicle is parked? I'm guessing most people will operate it this way, not turning the car on first before powering the dashcam back on.While unplugging and plugging the dashcam, the dashcam will consider the power cable is the car charger instead of the hardwire kits, so the parking mode is disabled.
So no corruption issues with doing so? When the vehicle is parked, the start/stop recording feature is disabled, same as accessing the settings menu. The dashcam behaves pretty differently when the vehicle is parked.In A329S series, it supports removing and inserting the memory card while the camera is working; it will not turn off the camera like other models.
For memory card removal, we still suggest stopping recording first.
When the A329S is in Parking Mode: "Low Bitrate Recording", I can stop recording and go to the settings menu.When the vehicle is parked, the start/stop recording feature is disabled, same as accessing the settings menu. The dashcam behaves pretty differently when the vehicle is parked.
Interesting. I tried low bitrate just now on my A329S and it won’t go into the menu when parked. When it’s set to AED or hybrid/AED, I can stop recording but the menu button takes a photo.When the A329S is in Parking Mode: "Low Bitrate Recording", I can stop recording and go to the settings menu.
I can't understand anything.Interesting. I tried low bitrate just now on my A329S and it won’t go into the menu when parked. When it’s set to AED or hybrid/AED, I can stop recording but the menu button takes a photo.
Why not use Wi-Fi and change the settings via the app?So no corruption issues with doing so? When the vehicle is parked, the start/stop recording feature is disabled, same as accessing the settings menu. The dashcam behaves pretty differently when the vehicle is parked.
The end goal is to remove the memory card safely, and we’re discussing stopping recording to avoid corruption. Easier to just hit the stop recording button than to do it all through WiFi. 🙂Why not use Wi-Fi and change the settings via the app?
I thought your goal was to change the settings while in parking mode.The end goal is to remove the memory card safely, and we’re discussing stopping recording to avoid corruption. Easier to just hit the stop recording button than to do it all through WiFi. 🙂
Ah you're right, we were also discussing different functionality available or not when in parking mode.I thought your goal was to change the settings while in parking mode.
I don't have my A329S yet, because it is being held hostage by USA customs, but I guess that customers were accidentally powering off their dashcams when only trying to get to the menu? I never turn my dashcam off. Do you do it often and have to do it in a rush?I'm not a fan of the "1" change since the long press of the "menu" button would power down the dash camera. Now, the long press puts you into the settings menu. To power it down now, you must continue to hold the "menu" [super long press] button even after it enters the settings menu.
