VIOFO T340 4CH - Q&A
That is great to hear. One facing front to back. Second one facing from the rear windshield to front of vehicle. Cool.
I think Chuck was saying "Yes" to the "Does T340 support (2) Rear Cameras?" question only, not to the other two questions.
@Chuck McCoy please clarify this for me.
Does 330 340 support 1TB memory card
i use 1t tf for viofo from 329 last year already
Q: Does T340 support (2) Telephoto Cameras?
Does T340 support (2) IR Interior Cameras?
A: Yes
The above was written by Chuck and then quoted by @viofo who then highlighted the Yes in RED.
OK, hereโ€™s what happened.
When I first made Post #1 it was only questions, (no answers).
At the bottom of the post I wrote;
โ€œIf you know any answers please drop โ€˜em bellow, and Iโ€™ll update this post.โ€
The next day Viofo-Support replied in Post #7 answering all the questions.
I then updated Post #1 with answers provided by Viofo-Support.
Take a look at Post #7.
I think Viofo-Support was saying YES, to all three questions.
Q:
A: YES
Since you have T340 on hand, can you confirm by connecting;
(2) Telephoto Cameras to T340
(2) IR Interior Cameras to T340
(2) Rear Cameras to T340
At the moment, I'm without a T340. The prototype unit I developed a problem. I'm waiting on a production T340.
While I agree, that the same image sensor is being used in each of the external cameras [IMX675], that does not mean the firmware can control/configure the stated configurations. That's what I pointed out in my other post in the other thread. The only "double" camera of the same type is with WW firmware when 1R/2R files are created. The only T340 official interior camera is the internal one. You might be able to plug an external interior camera to the "EXT" port, but you won't be able to fully configure the operations of the IR LEDs for that unit, unless the IR LED setting is a global setting. The T340 is going to believe it has a telephoto camera connected to the "EXT" port unless it has the WW firmware installed. I'd be happy to test this when I get my replacement T340 dash camera, but I don't know when that unit is going to arrive.
Right on, I forgot about that.
Since you have T330 on hand, can you confirm by connecting;
(2) Telephoto Cameras to T330
(2) IR Interior Cameras to T330
(2) Rear Cameras to T330
Looking at the T330 sub-models offered by VIOFO:
  • 2-Channel
    • T330 2CH : Front + Rear
    • T330W 2CH : Front + Waterproof Rear
  • 3-Channel
    • T330 3CH : Front + IR Cabin + Rear
    • T330W 3CH : Front + IR Cabin + Waterproof Rear
    • T330WW 3CH : Front + Dual Waterproof Rear
    • T330T 3CH : Front + Telephoto + Rear
    • T330TW 3CH : Front + Telephoto + Waterproof Rear
Based on how the A329S series and its several sub-model variants supported various camera combination by loading different firmware into the front camera, I would suspect the T330 [and T340] will need to load a firmware version for the specific camera combination being used so all features can be configured/controlled in the firmware settings.
My guess is that the T330 [standard configuration] will assume an interior camera will be connected to the "INT" port and some form of a rear camera will be connected to the "REAR" port. If you connect a telephoto to the "INT" port, I don't believe the T330 firmware will auto detect that it's a telephoto camera and switch the filename suffix to a "T" instead of an "I". I will check that when I get some time this weekend. I've been diagnosing my HHR which appears to have an A/C compressor leak and I was helping a friend figure out an aftermarket radiator cooling fan kit that arrived with zero instructions. Busy day.
  • 2-Channel
  • 3-Channel
actually i always use 329t firmware for my 329ww one year
  • 2-Channel
  • 3-Channel
I created a response to this T330 question in my T330 thread.
I don't see anything saying LPID is 1mA on the T330/340 series, compared to 39mA on the A329S series.
Oh, apologies, I misunderstood your actual question!
Where is this 1mA LPID information posted?
See POST #7 HERE ๐Ÿ‘๏ธ๐Ÿ‘„๐Ÿ‘๏ธ
A149 Pro Duo also has 1mA LPID SEE HERE
I got a tracking number for my test units last night, Iโ€™ll confirm in 7-10 days.
Ah, I see. If Viofo managed to reduce power consumption by a factor of 40, I was expecting them to have mentioned something about it on their product pages.
Hmm. Looks like 7mA to me, (on a pre-production unit with early firmware). That's still a decent low value though.
While the A149 Pro by itself consumes 1 mA {7 mA total - 6 mA consumed by HK6} in LPID parking mode, the entire power solution of the dash camera plus the HK6 hardwire kit's power consumption is a total of 7 mA. The 39 mA for the A329S is the total of the dash camera plus the hardwire kit as well. My power consumption measurements are the total power draw placed on the dash camera's power source {vehicle battery or dash camera battery pack}.
Wild that the HWK is now the biggest power hog in a setup.
I would of course also want to know the total wattage, who consume what is not so interesting when no matter what you cant be without either to do the task.
Correct.
Post #31 refers to 1mA power consumption when connected to BP60.
When using BP60 the included โ€œType-C Hardwire Output Cableโ€ is used, not HK6.
So when using a dash cam battery pack with LPID, power consumption will be 1mA right?
Hereโ€™s a demo comparing BP100 Type-C Hardwire Output Cable vs. HK6 in LPID
