VIOFO T340 4CH - Q&A
So when using a dash cam battery pack with LPID, power consumption will be 1mA right?
You're correct. There's no inline 12V-to-5V power adapter for that BP60 USB-C-to-USB-C dash camera power configuration, so the power draw should be close to 1 mA.
Q: Does T330 & T340 have 1mA LPID?
A: Yes
I just received confirmation from VIOFO that the T330/T340 LPID parking modes do not operate at 1 mA as was stated in post #7.
The T330/T340 operate exactly the same as the current version of the A329S series dash cameras with regards to LPID parking mode, meaning there is currently no 1 mA version of LPID parking mode for the T330/T340.
What about A149 Pro Duo, that still has it right?
@Chuck McCoy
Any pictures of the T330 / T340 Internals? I'm curious what their new heatsink looks like.
Also, I personally find the barrel shaped cameras perform much better than other designs. I am hopefully that Viofo has learned from the A139 Pro, and that this design addresses past issues.
I haven't looked, so this is a bit of a lazy man's question, but does the hardware in the T330 / T340 differ any from the A329S/T Series?
True, the A129 Duo was 1080P, so far less demanding hardware and heat generation
@Chuck McCoy
They're on the FCC filing here, which also showed the chipset was not an all new processor as previously claimed, but the older Novatek NT98530:
@Chuck McCoy
For discussion's sake, how do barrel-shaped dashcams perform better?
Regarding the heatsink. I don't have a T330/T340 on hand, but based on the area, the heatsink looks like it has only slightly more. But that is based on looking at photos. What I found with these dashcams is that I can modify the heatsink to pull more heat away from the board components, but the challenge then becomes getting that heat out of the dashcam enclosure. A larger heatsink doesn't always mean better component cooling if the heat can't escape the area. Two black surfaces in the same box can also absorb and feed heat back to the other emitter. Eventually, if everything is steady and even, an equilibrium is reached. But the heat is still excessive.
Less surface area exposed to the sun, smaller electronics, and in this case a heatsink that is about 30-40% of the board.
One thing I don't understand is why dashcam makers don't make casings Grey in Color. Black absorbs heat. Grey does not.
In this camera, the heatsink encompasses a large portion of the board itself.
I would have to measure the areas of a cylinder dashcam and a wedge dashcam to see which has the greater area and to determine the available internal volume. I seem to recall that BlackVue had a heat issue with their cylinder dashcam, but that was some time ago. As for color, people seem to want stealthy, so colors like white, dove gray, etc., are out of the question for many. It is the James Bond mindset, I suppose. I always want someone to see my dashcams; I want them to think twice up front before they turn too stupid. My car has always been a tool, not a status symbol, so I could live with a white or gray dashcam, to be honest. Hell, even off-white or dirty white would do.
I was looking at their layout. The components are in groups but spread out; that helps a wee bit. I would almost bet a dozen donuts that this T330/T340 gets just as hot on the outside as a wedge dashcam. Larger heatsinks are only so effective, depending on how well the dashcam body can move heat from the inside to the outside. I'm confident Viofo already knows the T330's thermal characteristics. Perhaps this 'new' CPU is running cooler, but trapped heat is trapped heat, when the car is sitting in the sun.
That's exactly it. CPU would be creating a lot of the heat inside too, so something that's on a less efficient manufacturing node is going to create way more heat. And the other factors in play too as you rightly say.
No longer "Hot Outside" but I do have Vantrue's Thermal Attachment. However, none of the cameras I own have a primary barrel shaped design. I'd be curious to see how the two compare (wedge vs barrel shaped) in heat dissipation. Yes, a larger heatsink can only do so much, but I surmise that if the heatsink encompasses much more surface area in a smaller case, it would act more efficiently. A guess, but of course a guess that would need proven by real world performance.
A Light Grey is stealthy. I still don't understand why there's resistance. Black is a double edged sword. It attracts heat and more prone to overheating. Therefore, you lose the benefit of recording. A Light Grey isn't all that noticeable and reflects heat.
I don't care if people see my cameras either. It's a deterrent. Plus, my cameras have been used 95% in accidents. Stealth doesn't matter, capturing the footage does!
Time will tell. Maybe someone in Australia who is entering summer can use a thermal gauge to compare the temps of the A329S to the T330/T340 @Augustus
Q: What’s the difference between T340’s built-in cabin camera, and RCC360 remote cabin camera?
A:
1.) OmniVision: OmniVision OS04J10 (1/1.88″) 4MP - Ultra Wide Fisheye (built-in)
2.) RCC360: Sony STARVIS 2 IMX675 (1/2.8'') 5MP - Ultra Wide Fisheye (remote)
NOTE: All Measurements Horizontal FOV
180° FOV OmniVision
181° FOV RCC360
122° FOV OmniVision (IR LED Emitters On)
105° FOV RCC360 (IR LED Emitters On)
203° FOV RCC360 (Fisheye Mode On)
105° FOV RCC360 LED’s On (Fisheye Mode On)
Q: How come T340’s built-in OmniVison doesn’t have Fisheye Mode Setting like T330?
A:
Q: How does OmniVision have wider FOV (LED’s On) than RCC360?
(2) IR LED Emitters = OmniVision
(4) IR LED Emitters = RCC360
A:
Q: Why didn’t VIOFO use STARVIS 2 IMX675 for T340’s built-in cabin camera?
A:
Q: What happens if you connect (1) or (2) RCC360 to T340?
A: Next post.
