VIOFO T340 & T330 - Heat Dissipation Test
Chuck McCoy
California
2027 Min. Spec: STARVIS 3 & HDR & 1mA LPID & 4CH & FastBoot
NOTE:
1.) All cameras are retail version, same as sold to customer, (not prototype / pre-production).
2.) All measured weights include Adhesive Mount, CPL Filter, SD Card.
As soon as Official / Public firmware is published on VIOFO website, I’m going to perform heat testing to see which camera shape offers “best” heat dissipation.
1.) Wedge
2.) Barrel
3.) Cube
I would like to include camera mass & exterior surface area as additional data points.
I just got done weighing cameras on my cheap kitchen scale.
But I can’t figure out how to measure exterior surface area with "consistent accuracy”.
There’s too many twists & turns for my ruler.
236g = T340 (4CH)
221g = T330 (3CH)
193g = S1-4K (3CH)
174g = A329S (3CH)
146g = A149 Pro Duo (2CH)
133g = E1 Pro (1CH)
125g = A119M Pro (1CH)
I remember a Star Trek episode (TNG) when Dr. Crusher examined a Cardashian in sick bay using a holographic three-dimensional body scan for life signs.
The scanner closely outlined the patients body.
Does anyone know where I can get my hands on a 24th Century 3-D Scanner to measure exterior surface area of these cameras?
@jsmith
@GPak
@rcg530
@SafeDriveSolutions
@Vortex Radar
@gse
@Julian23
@Karagandinez
NOTE:
1.) Wedge
2.) Barrel
3.) Cube
236g = T340 (4CH)
221g = T330 (3CH)
193g = S1-4K (3CH)
174g = A329S (3CH)
133g = E1 Pro (1CH)
@jsmith
@GPak
@rcg530
@SafeDriveSolutions
@Vortex Radar
@gse
@Julian23
@Karagandinez
Ask Patric Stewart. Maybe he still knows a thing or two about the Enterprise's Secrets!
Maybe you could use a piece of string to measure the circumference of each camera, then multiply it by the width or length of the housing.
You'd still need to account for the two end faces, and it wouldn't be that accurate for more complicated shapes, but it should give you a rough estimate of the exterior surface area.
Not perfect, but probably better than nothing, and fairly easy to do without any special equipment.
Thank you for the suggestion.
But, I think I would screw that up. lol
I was thinking about vacuum sealing the cameras in plastic bags, then dunking in water, and measure how much water was displaced.
Then convert that into "volume".
Volume should be related to surface area right?
Nah, I'll probably screw that up too.
I'm going to look for some kind of smartphone APP for measuring things.
Hopefully there'll be one that can do more than length x width x height.
If you approximate the T330 to a simple tube you should be close enough for any comparison tests:
Length = 5.35in
Diameter = 1.69in
Surface area = (5.35 x PI x 1.69) + (2 x PI x (1.69/2)^2) = 28.4 + 4.5 = 32.9sq in
Another option is to find a 3D printing shop with a scanning tool that measures an item. They usually place the item on a turntable and use a laser to scan its exterior. That information is then converted into a surface area model. Surface area is essentially what you want.
For interior volume, you scan the board and its components, then subtract that from the exterior dimensions, minus the housing thickness. This value is less important, but it still matters when considering vent holes and airflow.
You will need climate control for the area, and the units must be mounted by their base to a fixed object that does not reflect light or heat. Each unit should be at least 18 inches from each other, and ideally there should be a solid partition between each unit.
You need to know where the controller is located on the microSDXC card, as it is the hottest part of most microSDXC cards. So, external readings with an IR gun are somewhat flawed, since they measure the hottest part of the exposed card. Be careful to understand the impact on the readings.
You don't need to allow a cool-down period between testing an individual camera unless you are testing something like the Vueroid's ability to manage heat and recording, and you want to know at what external temperature recording or power changed.
Length = 5.35in
Diameter = 1.69in
Similarly for A329x:
This was my exact first thought.
But I have two issues;
1.) This does not account for the adhesive mount.
That’s why I included all adhesive mounts, and CPL Filters when weighing each camera on the scale.
These items help dissipate heat.
When I started testing with my Thermal Imaging Camera, Nigel noticed that even USB Cables were helping dissipate heat, (if they were connected to power, or not).
So every little bit helps.
2.) The wedge cameras have too many angles to make one “simple” formula like the tube.
But it looks like GPak figured it out, (but with no GPS Mount).
So far I like Lufa’s 3D solution best, because it will remove any inconsistencies, (me) from making accurate measurements.
God blasted!
Last year a 3D printer manufacturer sent me an email.
They wanted me to make a test & review video about their 3D printer, and put it on my main YouTube channel.
The printer was worth $2,000USD.
Looking back I should have taken that free printer, but I don’t make YouTube videos anymore.
Wow!
Thank you.
Ain’t none of this matter as long as both cameras operate under identical conditions.
I’ll only be testing two cameras at a time, (1 v 1) LIKE HERE
Thank you all very much.
-Chuck
@Chuck McCoy .. That distance between two cams is probably OK. There is a 'view factor' where the dashcams see each other and try to swap off heat or energy, especially since both are black in color. At 18 to 24 inches, that visibility is very, very small. What this means ultimately is that any energy reflection from the cameras, or the back wall, regardless of color, is diminished quite a bit. This makes your testing a bit more accurate.
My meters have the thermal probe accessory, which is handy for quickly testing the air immediately around the dashcam. You could probably also use one of the digital oven thermometers. This can be a way to validate your IR gun readings. Though there is usually a small variance between the two.
The GPS module attaches to the dash cam; the side facing the windshield is already accounted for in the basic dashcam surface area.
We only need to add the surface area of the GPS module's sides, calculated as follows:
[ 2 × (GPS length) + 2 × (GPS width) ] × GPS thickness
I measured the dimensions of the GPS module for the A329S model: length — 48 mm, width — 40 mm, thickness — 12 mm.
(Please verify or adjust my GPS measurements, as I took them while the module was already installed and access to it was limited)
Thus, the surface area of the GPS sides is: 2,112 mm² (or 3.27 in²)
Regarding the CPL filter: the glass surface area is already included in the dash cam's total surface area.
We only need to add the CPL's side surface area, calculated as follows:
Pi × Diameter × Thickness
I measured the CPL filter's diameter (27 mm) and its thickness (approximately 5 mm).
Thus, the CPL's side surface area is 424 mm² (or 0.66 in²)
“We” all use the same TOPDON TC004 Thermal Imaging Camera.
Just like “we” all use the same Fluke 117, and NANKADF Power Supply.
Any thermal image measurement I make, can be quickly / easily verified by another tester.
@rcg530
@Vortex Radar
@SafeDriveSolutions
Anything these days is cheaper than a FLIR camera.
I'm not part of that "we" as I use a Victor 328B so I more than halved the price of that Topdon again. And it's compatible with the Topdon app too lmao
