Voltage drop when plugging in DR750S-2CH - BMW F10 520d
generalk
SA - Adelaide
Hi,
I recently installed a Blackvue dash cam with a power magic pro and wired it back to the fuse box in the boot. It worked for a day. After leaving it on the 12 hr timer overnight I returned to the car in the morning and received the battery discharge warning (expected).
However, the camera no longer powered on with the car.
So I got the multi-meter out and did a little prodding around. It seems that before the dash-cam is connected to the power magic device, it is putting out 12-12.5 v as expected.
However, when I plug the dash cam into the socket voltage across the entire fuse box falls to around 4.5v. This in turn spawns a whole heap of under-voltage errors that I was able to read out of the ECU.
To try and narrow it down I've connected the dash cam directly to the cigarette lighter in adapter in the centre console & it works fine.
I'm wondering if anyone knows what could cause such an issue?
Fuse box pic attached.
Ben.
