Vueroid S1 4K Crown (side cable downgrade)
Chellotta
London
Dear Vueroid,
I’ve been waiting for an upgrade to the S1 4K Infinite for a while, as you can see that the Vueroid designers understood the brief on how to incorporate all the right features into a high end dash cam.
BUT…
Why on earth is the rear camera cable coming out of the side on the new model??? It feels like a massive design downgrade and like the people making it haven’t actually installed it on a windshield or don’t care about the messy look it creates.
I get it, some people out there drive around with a cable dangling down from their dash cam to the cigarette lighter port… but most of the people buying your high end multi channel dash cam will have it professionally hardwired with as much of the cables hidden as possible… why actively make this harder to do? You would think this is a key factor in the design process - how the camera installs? A dash cam shouldn’t stick out like a sore thumb and turn a tidy new car interior into a taxi.
I know other dash cam companies do this too, but I had higher expectations of Vueroid because they had a great start with the S1 4K Infinite.
Please Vueroid, fix this design or engineer a better cable solution going forward to accommodate all your different cameras and modules without plastering cable ports on all sides of the camera. Maybe a cable splitter? Maybe a central box design?
Disappointed rant over. Does anyone agree with me??
I actually don't think that it's that bad.
The prior design with all 3 cables at the top of the GPS module caused the cables to be very crammed.
With one cable on the side this could makes room for the two cables on the top.
But this is of course personal preference.
I understand why they did it, more cameras/modules to connect to and whatnot… but in my opinion the dash cam community isn’t critical enough of visible cables on the windshield, so manufacturers essentially create a cable ‘hub’ right in your eyeline.
As an example of an engineered solution around this, BMW ACE dash cams (which are essentially a rebranded Thinkware product), have a single braided cable that comes out of the top of the camera base and splits in the headliner into the rear, power etc… This is acceptable for BMW to have installed on a new car in a showroom. A lot of dash cams have 3 types of different cables coming out of different sides of the camera, all with different rubber cable boots of various sizes, some angled, some straight… it quickly starts looking messy.
I agree, the top 3 cables on the s1 infinite could be slimmed down with thinner connectors or a proprietary single branching connector. But cable on the side is too big a step backwards into the generic dash cams design space IMO.
Dear Vueroid,
BUT…
Your thread title is misleading and typical clickbait. There is no downgrade between the S1 4K Infinite and the S1 4K Crown. Only your misunderstanding.
The S1 4K Crown has a wonderful set of new features and accessories; there is no downgrade at all.
Do you know what that side port is used for?
I’m glad you like the S1 4K Crown. And I’m sure that it will technically be one of the best dash cams on the market.
But if you read beyond the title, I’ve explained my opinion on how the cable position is a downgrade. Each to their own, but I don’t think I’m the only person wanting a dash cam without a cable hub mounted on my windshield. Year after year, no manufacturer seems to want to innovate the connectors and cables to allow for a truly clean setup.
I’m only critical of Vueroid because I really liked the S1 Infinite and very much wanted the Crown to be an upgrade in all aspects. But wiring on the side is too much of a generic aftermarket dash cam anesthe and impossible to hide so it’s a no-go for me.
I’m keen to see what else is previewed at SEMA.
I did read your thread....that title is clickbait. It's amazing that you view something as a downgrade when it isn't. A downgrade would be going from 4K resolution to HD resolution.
As for wiring, here is the story. Dashcam users complain that the wire is too thick to pull through the car, too thin, or not sturdy. They don't like this connector or that connector. They want right-angled connectors, and they want straight-ended connectors. They want one wire, but it has to be thin and carry all digital signals for up to 4 channels. They don't want proprietary wiring or connectors. Some want 12 volts, and some want USB power. At the same time, they want an OBD II port cable and connector. They want all of this to work flawlessly with ICE, Hybrid, and full EV automobiles. They want all of this for under $300 dollars.
Well, this is a forum for sharing opinions, and criticism of a design flaw on a dash cam I genuinely wanted to buy isn't "bait", it's valid feedback. A downgrade isn't limited to video resolution, ergonomics and industrial design matter just as much.
I understand that buyers have competing demands for power options, wire thickness, and vehicle compatibility. However, what you’re describing is really just framing a lack of cable innovation as a feature. Moving a port to the side doesn't solve cable management, it just shifts the problem from Vueroid’s engineers onto our windshields. Whether someone uses OBD, 12V, USB, or drives an EV, every single one of those cables still has to route upwards into the headliner, never sideways across the glass.
A clean, OEM-style install routes wires straight from the top mount into the headliner with very little exposed cable. Putting a port on the side of the main unit forces an unsightly cable across bare glass before it can be tucked away, and depending on whether your car is RHD or LHD, that side port can end up facing the wrong side of the mirror housing altogether.
Worse still, keeping the rest of the ports on the removable GPS mount while tethering the rear cable directly to the camera body completely defeats the purpose of a quick-release mount.
As a consumer, I’m not here to be an unpaid apologist explaining away a manufacturer's design compromises. I’m giving real-world feedback on something I care about when choosing a dash cam: how cleanly I can install it and hide the wires. If users keep making excuses for brands or accepting a mess of cables on the windshield, nothing will ever improve. In the age of the iPhone, expecting clean, unified cable management on a flagship dash cam isn't asking too much.
I do agree that cable management could/should be done better, a single flylead with breakout connectors, say, 150mm long tethered to the main unit or mounting base would be much less visually jarring than several ugly jack connectors, I get it that the additional camera design means that connectors have (generally) to be where they are, but how much extra work and cost would it be to include or offer as an accessory a right-angled 'slim' connector extension lead, assuming the standard connector is straight?
The connectors themselves seem to be the standard 2.5mm or 3.5mm multipole type, this is effectively a fixed installation so why do the connectors and cable outer insulation need to be so bulky and include the standard strain / bend relief for devices that are regularly moved or disconnected? that makes unobtrusive installation next to impossible.
For myself, I've gone with a Vueroid D40-Q2, I would have liked to have bought a 4k system but all the current options have a screen and/or quite a large footprint. The D40-Q2 is a very neat solution - excepting the lack of right angled camera connectors or adaptor leads (I did try the standard Amazon adaptor lead with no success) A 4k camera option with 5GHz WiFi and optional slim right angled camera adaptor leads would make a perfect unobtrusive dashcam system.
As already mentioned, this 'problem' isn't exclusive to Vueroid, they do seem to be more responsive to improvement suggestions than most though.
I previously owned Thinkware 'tube' type camera's - these were unobtrusive and easy to hide away in RHD vehicles, I know that a fair proportion of the world drive have LHD vehicles so it makes financial sense to design for that market, a little thought in cable management or mounting can change an installation from looking like a dogs breakfast into something that is less jarring.
Of course, all this would come at a premium - would people be willing to pay that?
Ask Apple....
Perhaps it's worth asking the question - "why is the rear camera cable connection on the side?". It was not there in the previous version of the S1. I doubt it happened by accident. So I assume there's a logical reason why Vueroid chose to put it there.
I haven’t seen this model before, so I have a question:
Is this definitely a port for connecting a rear-facing camera?
Or is something else supposed to be connected there?
For example: an LTE module, a telephoto lens, a thermal imager, or something else entirely...😉
Ask Apple....
I completely agree. Especially regarding your point that this is a fixed installation and the cables don’t necessarily need the same durability of a frequently handled device… they can be thinner and use a smaller connector.
I have to look into the D40-Q2 a bit more. It may be the compromise I have to make. Resolution is not as much of an issue if you live in the UK, as our licence plates are bigger with larger font. Also maybe a lower resolution would allow for more recording time and lower power usage during parking mode? I do want that 3rd channel though… argh!
I think I probably would pay a premium for that ideal dash cam if anyone ever makes it. I previously had a Blackvue 2ch 750x LTE with the tamper-proof mount, although I probably wouldn’t buy a Blackvue again as it’s just not reliable (far too many times has it frozen and glitched out, not recording anything at all). Having said that, my install was clean, the tamper-proof mount hid the connectors and I sleeved the cables together and routed them through a small hole in the mirror base and up to the headliner. Completely invisible.
I guess we’ll find out soon, but my best guess is that it’s a cost cutting measure. Vueroid seems to have reused the design (and therefore probably many of the components) of the S1 infinite which originally accommodated the three connectors on the GPS mount. Now they’ve made some new modules and cameras but kept the same form as before, they had to crudely add an additional port somewhere where there was space (on the side) as putting it on the GPS mount would involve too much redesign of the mount, pin layout etc etc…
Although this is completely an assumption and I’m sure someone with more information can correct me soon.
@Vortex Radar said it was the rear camera port in his YouTube short:
It looks like an MCX or MMCX coax connector, similar to those used by other dashcam manufacturers, possibly to support the move to lossless digital video transmission on the rear camera.
I’ve already watched this video...
A Type-C connector simply wouldn’t have fit on the GPS module.
It looks like there are two ports on the side, one Type-C and one for a rear dash cam. The Type-C port can connect the dash cam to your phone to download videos rather than using WiFi (I believe this is the case, if it functions like the S1 Infinite), but the camera port will always have a cable attached to it.
Thank you for your interest in VUEROID products.
Regarding the rear camera cable port being moved to the side, our design and engineering team spent a great deal of time weighing this decision. We are fully aware that having all connections on the GPS mount, as seen on the S1 4K Infinite, offers a cleaner look and better installation convenience.
After launching the S1 4K, we listened closely to the valuable feedback from the market regarding video quality, the mobile app, interior camera functionality, and the demand for a telephoto option. We reviewed every aspect to bring significant improvements across the board:
  • Front Unit Video Quality: Completely re-evaluated and re-tuned for clearer image capture.
  • Interior Camera: Upgraded resolution from FHD to QHD.
  • Telephoto Camera: Newly developed from the ground up to expand options.
  • Mobile App: Continuously refined for better stability and user experience.
To improve the video quality of the rear camera, we realized that our previous analog transmission method had its physical limitations. We made the technical decision to switch to a lossless digital video transmission protocol, which provides superior image clarity over analog.
However, due to the high-frequency signal characteristics of digital transmission, passing the signal through the extra contacts of the detachable GPS mount introduced signal degradation and reliability issues. Because our top priority was delivering uncompromising image quality, we made the choice to move the port directly to the side of the main body.
While the new cable architecture and digital transmission technology increase overall manufacturing costs compared to the original Infinite model, the resulting video quality is a noticeable step forward. In short, we prioritized image quality and signal integrity over installation cosmetics.
We truly appreciate your candid feedback—it is exactly this kind of real-world community engagement that drives our future product development.
Thank you for taking the time to reply directly and explain the engineering behind the change, I really appreciate a manufacturer engaging with community feedback.
While I understand the push for lossless digital transmission, I’m not sure I fully agree with sacrificing physical integration for marginal gains in rear-camera clarity. The image quality on the S1 4K Infinite was already excellent, so this feels like losing sight of the main point of the device.
A dash cam isn't shooting a Hollywood movie, its primary job is to prove fault in an accident, or catch an incident while parked. I get that in today's market, every new release inevitably gets put through side-by-side YouTube comparison videos where reviewers zoom in 400% on freeze-frames to crown a winner based on pixel-peeping.
But once video quality is already at a high standard, chasing slightly sharper pixels shouldn't come at the expense of the product as a whole. For buyers fitting a flagship system into a tidy, modern car interior, industrial design and stealthy installation aren't just minor "cosmetics", they are a massive part of the daily ownership experience.
The only reason I’m calling Vueroid out on this, rather than the other manufacturers who do the same thing, is because you are already doing so much right. Vueroid is probably the only dash cam brand I would consider buying in the current market, which is why I was really hoping the installation on the Crown would match the Infinite or improve on it.
I genuinely appreciate the transparency, and I hope for the next iteration your engineering team finds a way to deliver that digital signal integrity while also routing all cables cleanly upwards from the top of the unit (or surprise us with a much better solution).
Thank you for your valuable feedback. As you suggested, we plan to give this serious consideration for our next product lineup. Keeping the digital signal integrity while routing the cables cleanly is not impossible — it mainly comes down to a difference in cost. But I can assure you that you will see an improved product in the future.
I strongly suggest that you take a closer look at the fundamental differences between LVDS-based digital SerDes technologies and analog transmission technologies such as AHD, particularly in terms of image signal transmission.
You should also take the time to understand the cable and connector requirements for each architecture, including automotive-grade solutions such as FAKRA.
Most OEM automotive camera systems rely on high-speed digital SerDes interfaces, such as FPD-Link and GMSL. These systems have very different requirements in terms of signal integrity, cable specifications, impedance, shielding, and connector design compared to conventional analog video transmission systems.
And honestly, when I came across the term "cost reduction" in this discussion, I couldn't help but find it rather ironic. It suggests a fundamental misunderstanding of the overall system architecture.
High-speed LVDS-based SerDes solutions generally add significant system-level costs due to the additional serializer/deserializer ICs, high-bandwidth cables, dedicated connectors, and associated circuit requirements. This is a well-known trade-off in automotive camera system design.
(Some of OEM adopted AHD imstead of Serdes to reduce the cost)
That brings me to a much more fundamental question:
If there had been a technically viable way to retain the original configuration without compromising the system, why would Vueroid have deliberately made this change, especially when they fully understood that it meant giving up one of the product's key advantages?
There must have been a technical reason behind that decision. Anyone who understands the underlying signal architecture and its system-level trade-offs should be able to recognize this.
Regarding the current design, I would much rather retain the side port than introduce additional interconnections between the mount and the main unit, potentially compromising signal integrity and creating unnecessary points of failure.
Ultimately, if Vueroid asked me to choose between better image quality and having all the ports integrated into the mount, my answer would be absolutely clear.
"I would choose better image quality without hesitation"
We should be making engineering decisions based on technical facts, signal integrity, and overall system performance — not superficial assumptions about cost reduction or design convenience.
