Hi All.
I’m running a BlackVue 900 2ch hardwired with a power magic pro. And an AT&T Nighthawk hotspot on a different power magic pro.
Since the Nighthawk has a battery. I have the power Magic’s set to turn off at different voltages. The one to the Nighthawk turns off first. So that the camera can stay on longer. And since the hot spot has its own battery.. it stays on.
I want to get the camera setup the same way.. and I don’t need a battery that will last 20 hours.. anything between 4 and 6 hours should be good.
So basically a battery that can be connected between the camera and the power magic pro. The ones that they sell for this specific purpose.. only recharge when the truck is running. I need one that will act like the internal battery that the Nighthawk has.
And also a battery that has an off button.
My drive to work is only about 20 minutes one way. So one of those big batteries wouldn’t work because it won’t have enough time to recharge.
With the hotspot. When I get home. The cam connects to my hone network. So I turn it off.
I want to be able to do the same thing with a battery handling the cam.
Any ideas ?
I hope I’m making this clear enough.
TIA.
Any ideas ?
TIA.
